p0336 car will not run or idle
Old Apr 25, 2014 | 09:02 AM
paintballerr78's Avatar
My car Started throwing a p0336 code after cam install and zzp dyno tune they did all the work. At first the car wouldn't crank first try but second attempt would start right up. Now the car won't even idle it'll crank over but idle just jumps from 400-1300. I have so far replaced the crank position sensor/crank position sensor wiring/main engine wiring harness/both cam sensors/pcm/ checked all fuses and under the fuse box for bent pins and still the car will not idle. As of right now I am at a complete stand still. I've checked the crank sensor plug and I get the readings as stated it should. Any input would be greatly appreciated. Its now down to trying random things IE putting more gas in the tank/changing my oil possibly even dropping the oil pan to see if the reluctor wheel is messed up but the bottom end has never been touched so we are kinda steering away from that.
Old Apr 25, 2014 | 09:14 AM
double clutch's Avatar
Mine car did this out of the blue yesterday. I was throwing the same code. Turned out my belt was too loose so it was slipping trying to start and the crank pulley wasnt spinning all the way. Im not saying this is ur problem, just what happened to me.
Old Apr 25, 2014 | 09:29 AM
Hmm ill look into that thanks
Old Apr 25, 2014 | 09:44 AM
68Vette's Avatar
The book says: (1) Crankshaft Position Sensor rationality check, primary malfunction: unexpected re-synchronization > 2600 count (loss of reference mark) (2) Cam shaft Position Sensor bank 1 exhaust plausibility check: primary malfunction: signal erratic or out of position. Hope this helps.
Old Apr 25, 2014 | 09:52 AM
So not my belt checked that. And it's saying check the exhaust cam sensor from my understanding right
I've changed the exhaust cam sensor already along with the crank sensing kinda just throwing a hail Mary but with a bent pin going to my ecu fuse could that of caused my sensors to slowly short?
Old Apr 25, 2014 | 11:51 AM
A bad ecu can cause that code to throw. So that pin can be messing up the readings to the sensors
Old Apr 25, 2014 | 11:57 AM
I've changed my ecu since I found that bent pin I'm just wondering if maybe the cam sensor is messed up from the pin being bent
Old Apr 25, 2014 | 01:04 PM
The car will still run with a messed up cam sensor but not a crank sensor
Old Apr 25, 2014 | 01:08 PM
This might help
http://www.obd-codes.com/p0335
Old Apr 25, 2014 | 03:05 PM
Sensor has power on all 3 ports changed plugs idk what else to do last thing I'm trying is adding gas then I give up
Old Apr 25, 2014 | 04:56 PM
Well looks like the car is going to the dealership. With the cost to ship it to zzp is 900 plus labor would put me near 1500-2000 I'd estimate
Old Apr 25, 2014 | 06:02 PM
Hopefully the stealership actually knows what they are doin for once
Old Apr 25, 2014 | 06:12 PM
Well find out by Thursday
Old Apr 30, 2014 | 10:56 AM
Well dealership cant figure it out either...looks like i just have a giant paper weight now
Old Apr 30, 2014 | 11:20 AM
unplug the battery? idk im no help haha
Old Apr 30, 2014 | 12:39 PM
only thing i can honestly think of is maybe the sensor i got sent is shot from the factory. We checked the reluctor wheel and it was fine nothing wrong at all.
So the pcm/main engine harness/sensor harness/sensor/reluctor wheel has all been changed or checked to make sure its not broken only thing i can think of is the sensor is faulty maybe
Old Apr 30, 2014 | 01:27 PM
put your wheels & coils on while its being a paper weight
Old Apr 30, 2014 | 01:37 PM
i have all my stuff on my car already its been on for a year...or are you talking about for sale haha
Old Apr 30, 2014 | 02:17 PM
at this point im not sure haha
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
medic710
Sep 6, 2015 08:53 PM
Adam144
Sep 3, 2015 07:48 PM
