Parts for engine build
Hey Guys, I can't seem to find the thread for recommended parts to replace when diving into the motor. I thought I saved it but I guess it fell through the cracks.
Throwing on a BNR turbo in the next couple weeks. Also going in is a zzp stock cam with fuel lobe and their injectors and fuel pump. (Car has over 100k miles and I beat the hell out of it)
What do you guys suggest replacing while the motor is under the knife just to be on the safe side? So far I have ARP head bolts, Cloyes timing set, zzp 82lb springs, maybe a front cover just for the oil pump......What else do you guru's think needs to be installed? Any info would be appreciated
