People with Crazy Steve IC...
Hey gals/gals...i just got a Crazy Steve IC and am just wondering how you all mounted it...did you use the side tabs or the top bolt holes? I figured the top bolt holes were the norm so i used them but after bolting it up it doesn't line up with my hot or cold side pipes...WHAT GIVES? i have stock cold side and Dejon hot side pipes. Any tips or info would be great help as im sitting in front of my car staring at it lol
what I did and everything worked great it took about an hour tho.
I took the bumber off and the beam I jacked it up put my charge piping on (it is hard to do with little room) the I used the holes that where holding the beam up, I put the bolt through the beam and the IC mount...I put in all the bolts in the beam and tightened it tell the beam molded over the IC mounts. It looks like it came with the car and the dealer will never know!
I hope this helps
I hope this helps
