The Perfect Launch
The Perfect Launch
I know that there are launching treads but i mean practically all are about the ss sc i want to know what the perfect launch is all about like down to the T please.
Its probably more suited for the drag strip where the track is nice and sticky, i wouldn't expect that to work on the street.
Um....nope. That is the average for street tires. There is no perfect launch because conditions are different everywhere. A great launch is as best as you can get. If you can hit a 2.1xxx with street radials then you are doing great in a FWD car.
well from what i hear 2500 is a good point.. just go to a track and practice... do a few runs with launch control then try changeing up rpms.... launch rpm will change from track to track..... lol like my lowest time using launch control was a 14.2 which isnt horrible but still could be improved...
you want just a LITTLE bit of wheelspin. no hop. a lot of times your gonna have to feel it out. you cant really tell someone how to do it. Go practice!!!
its called pre-loading, you set the e-brake and allow the car to set against the ebrake with the clutch out a little while building up RPMS, its supposed to make you launch harder and smoother,
I have also been told that it will protect your axles because the dont receive as much shock when u launch the car
just a min and i can post a vid of a guy doing it
nvm, i couldnt find the video, i personally have never done it, i use another technique but a buddy of mine swears by it
i have tried both methods... i went from 2.3's to 2.1 and NO WHEEL HOP
ok when you pull up to the line you do this:
1. Stage
2. You let the clutch a little out just so it grabs
3. As soon as it grabs you hold the E-Brake up
4. Then bring your tach to whatever you launch at
5: soon as the last yellow light hit you throw the e-brake down
Since your clutch is all ready grabbing your car takes off and you just let go of the clutch its very simple
It takes all the tension off your axles... but it does hurt your clutch a little
Try it in a parking lot or something... Believe me it works man
1. Stage
1. Stage
1. Stage
dude its very very very easy.... as long as your not lazy and throw the ebrake the whole way down your car will shoot off like a rocket... you will think your car is all wheel drive....dont have pedal to the floor and ure tires wont spin.... i launch my car around 4k and my tires dont spin
