Performance coil pack
Hello
Since ZZP High Voltage are not available since long time
Any comments on this one ?
https://www.ebay.com/itm/Ignition-Co....c100005.m1851
Unless you're running super rich and massive, massive boost that's causing a problem with spark blow out the stock coil packs should be more than enough. For the most part you either have adequate spark or you don't. Many of the aftermarket coils claiming higher "voltage" also have a pretty high failure rate.
The misconception about ignition coils is people think a 40kv coil sends 40kv to the plugs.... all the time. Coils only release (collaps) what is necessary to jump the gap of the plug. As Blackbird said, and I will add to it. Unless your blowing out the plug and it isn't a plug or mixture issue and your racing for money, the OEM coils should be plenty.
Has anyone actually checked the Available voltage of a ZZP coil on a scope?
I don't even see where they list the available KV.
originaladrian
Jun 15, 2009 09:19 AM
