Photo Required - Fuse Box
Hi Guys,
could someone post me up a photo of their fuse box in their engine bay?
i have a wire heading into the box and under a fuse. trying to figure out if any other lnfs have it, or if it has something to do with my starter.
thanks.
thanks.
No, that wire is not supposed to be there.
Its tapping into what appears to be the starter relay and I guarantee its for your remote starter. Remove it if you aren't using the remote start.
Last edited by FasterIsBetter; Jun 18, 2012 at 01:33 AM. Reason: Automerged Doublepost
Thank you Faster,
one more question before i try removing the remote starter itself.
under my dash on the left side, there is a white or yellow wire with a fuse attached to it.
kind of like the below.
http://img.alibaba.com/img/pb/515/53...535515_584.jpg
is this part of our cars?
No, it is not part of our cars. It most likely runs directly to a power source like the battery or the post under the hood on the fuse box and is for the remote starter. In the stock wiring everything leads to the fuse box in the center console kick panel or the one under the hood which is already fused in either.
Try looking at the battery in the back or the fuse box post for any small wires with a ring terminal on them. I bet it was ran to your battery as I see no wires leading off your terminal on the fuse box under the hood. Disconnect that wire from thw battery before completely removing the remote start.
on my terminal on the fuse box are two large wires, and a third for my relay harness.
Thats weird. It was tapped into a power source somewhere else then. Just remove the fuse from the line under your dash then disconnect the remote start with that wire taped up. The wire will not be live with electricity if the fuse is pulled.
