Photo Required - Fuse Box
Old Jun 17, 2012 | 02:59 PM
wol-shiver's Avatar
Hi Guys,
could someone post me up a photo of their fuse box in their engine bay?
i have a wire heading into the box and under a fuse. trying to figure out if any other lnfs have it, or if it has something to do with my starter.
thanks.
Old Jun 17, 2012 | 05:02 PM
FasterIsBetter's Avatar
Post a photo of the wire and fuse box. We'll tell you where it goes. Prob goes to the big post terminal on the front right if it goes to the starter.
Old Jun 17, 2012 | 05:06 PM
But you say under a fuse? There shouldn't be any wires under a fuse unless someone had a meth kit in your car before you or maybe an amp??
Old Jun 18, 2012 | 12:46 AM
wol-shiver's Avatar
Here you
Wire goes into the crank fuse.
i have not tried following the wire, but i beleive it is for my remote starter.
If it is, can i simply remove it? i have already turned off the remote starter.
let me know, thanks.
Old Jun 18, 2012 | 01:05 AM
tomj77's Avatar
well u can remove any wire thats not normally there, it will just make whatever it is not work, wont harm ur car in any way.
Old Jun 18, 2012 | 01:24 AM
wol-shiver's Avatar
Thats my question, is it not supposed to be there?
thanks.
Old Jun 18, 2012 | 01:33 AM
No, that wire is not supposed to be there.
Its tapping into what appears to be the starter relay and I guarantee its for your remote starter. Remove it if you aren't using the remote start.
Last edited by FasterIsBetter; Jun 18, 2012 at 01:33 AM. Reason: Automerged Doublepost
Old Jun 18, 2012 | 01:39 AM
wol-shiver's Avatar
Thank you Faster,
one more question before i try removing the remote starter itself.
under my dash on the left side, there is a white or yellow wire with a fuse attached to it.
kind of like the below.
http://img.alibaba.com/img/pb/515/53...535515_584.jpg
is this part of our cars?
Old Jun 18, 2012 | 01:51 AM
No, it is not part of our cars. It most likely runs directly to a power source like the battery or the post under the hood on the fuse box and is for the remote starter. In the stock wiring everything leads to the fuse box in the center console kick panel or the one under the hood which is already fused in either.
Old Jun 18, 2012 | 01:55 AM
Try looking at the battery in the back or the fuse box post for any small wires with a ring terminal on them. I bet it was ran to your battery as I see no wires leading off your terminal on the fuse box under the hood. Disconnect that wire from thw battery before completely removing the remote start.
Old Jun 18, 2012 | 02:00 AM
wol-shiver's Avatar
I will do that thanks.
on my terminal on the fuse box are two large wires, and a third for my relay harness.
Old Jun 18, 2012 | 02:03 AM
Yeap, thats fine. As long as there isn't a fourth wire you are good. Its on the battery then (or should be).
Old Jun 18, 2012 | 02:13 AM
wol-shiver's Avatar
Just checked my battery.
nothing :-(
wouldnt the module be running enough power off of that fuse maybe?
thanks FIB
Old Jun 18, 2012 | 02:24 AM
Thats weird. It was tapped into a power source somewhere else then. Just remove the fuse from the line under your dash then disconnect the remote start with that wire taped up. The wire will not be live with electricity if the fuse is pulled.
Old Jun 18, 2012 | 02:28 AM
And that line under your hood isn't going to a fuse, thats a relay for the starter.
Old Jun 18, 2012 | 03:20 AM
wol-shiver's Avatar
Thanks F.
i guess i can just pull off the relay and pull of the wire underneath?
thanks again.
Old Jun 18, 2012 | 02:23 PM
Yeap, but put the relay back of course.
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
