Does anyone have an installed picture of their Powell AOS? bought mine second hand going to install tomorrow with no instructions. Really just looking on where to mount the seperator itself, im sure i can figure out the rest. thanks in advance
Powell usually has instructions for every part they sell. I would think that they should be floating around somewhere or you might be able to email Gloria gloria@powellraceparts.com and ask her for instructions even though you bought it second hand.
If I remember I'll pm you pics later of the mounting location (no guarentee I'll remember), so it mounts on the passenger side above the serpentine system directly to the engine. I forget right now if it's the head or block
This is mine. Version 2, I think. The one before the PCV eliminator version.
The near 90-degree elbow going into the valve cover is one hose and the other fitting at 12 o'clock from that elbow in the picture, oriented lower in the engine bay and out of focus going into the turbocharger is the other hose.
Welp got the can and dipstick in before I realized that the lines don't work with the zfr. I'll have to send Powell a message. That's again for the replys
you need an adapter for the zfr. easy way to fix is remove zfr fitting for the pcv and install a 1/4 npt to an6 adapter. I believe that's the threads on the zfr. if not, then whatever it is to an6. lol that's what I did. need a 45 degree an6 to npt adapter fitting
