Piston Issues =... Forged Piston Group Buy?!
That could be an issue. If that sensor is reading wrong the car is going rich lean rich lean and so on which will cause engine damaging knock and misfires (not as bad but will kill your cat)
Anyhoo... back on topic.
Those temp cells are used daily at crusing speeds. It is the sensor itself that is normally bad BYT replaced his and now his car runs a ton smoother and better according to him.
yea, ok i c ur point, i just want them because im gonna be in there anyway ya know......
hell no! i would never sell my car cuz you know when we fix all this problems the car would be a beast!
i still have faith that we will fix every problem that the car has...
anyways so there is no point on changing the pistons even if i were to go big turbo? just with a good tune it would basically solve the whole "pistons problems"?
I'm starting to wonder if the wideband O2s starting to go out but not tripping a code yet could be a contributing cause. They may be suddenly causing the car to run lean and knock and messing up the pistons. We could be treating the symptoms but not the cause. This might be hard to catch/diagnose for people without HPT or RPD/equivalent.
