Power Loss!
Old Jun 23, 2011 | 10:46 AM
USAMPDUFFY's Avatar
From: Home: Charleston, WV / Living in:Ft. Riley, KS
Power Loss!
As the title says, I'm having major power loss issues. I had the SS repaired at a dealership due to a melted head, the car runs fine under regular driving conditions, however, its just not up to par on the power side of the house...Before the work was done the RPD was reading 360tq and 340hp with the tune, now im reading 300tq and 250hp with the tune...I really have no clue what the problem is but the list of parts include all new gaskets, heads and sleeves....and ideas? I was pouring out grey smoke prior to the repair just for reference...any ideas of whats going on? Also, the last time I drove the car was in mid March and I just got back into it this past week so could ambient heat cause that much of a power loss?
Old Jun 23, 2011 | 11:00 AM
Iam Broke's Avatar
What kind of boost are you seeing and is it stock or GMS1?
Old Jun 23, 2011 | 11:01 AM
09CobaltSS1's Avatar
yeah.. the dealer most definitely flashed you back to either stock or gms1
/thread
xodus's Avatar
The rpd isnt too accurate after a tune, im making around 360 370tq and my rpd only reads 300-320, put it on a dyno and see what happens.
Old Jun 23, 2011 | 11:07 AM
USAMPDUFFY's Avatar
The dealer didnt flash me back, I untuned it before I took it in, and I retuned it last week...I'm seeing anywhere from 20-23psi with the same amount of power...and I used to run dead even with the two other SS's my buddies own with the same tune on, but not any more.
Old Jun 23, 2011 | 11:34 AM
ford's Avatar
/thread
This is what i thought immediately into his post.
But now you claim it has been retuned and still no change. Did you notice the numbers before you retuned? I am not sure if the lower numbers you reported were before you re-flashed or after.
Old Jun 23, 2011 | 11:38 AM
USAMPDUFFY's Avatar
after the build it was stock tune, so I retuned it afterwards and Im seeing the reported numbers.
Old Jun 23, 2011 | 11:42 AM
ford's Avatar
Do a compression test, as it sounds like you had a lot of work done with the sleeves and head work. I will assume from the monitoring side of things you havent noticed any boost leak and its still peaking/holding where it normally does?
Old Jun 23, 2011 | 12:59 PM
USAMPDUFFY's Avatar
The car checked out fine from the dealership, they did a compression test and it was all good, the car is peaking at around 22ish when it used to peak around 24ish, i took the chargepiping off and put it back on again to ensure im not leaking, I checked the hot side as well and it appeared to be okay...what shouild I read without the tune on? It may just be the tune itself?
Old Jun 23, 2011 | 01:28 PM
rukkee's Avatar
Did they put rings and pistons in it when they re-sleeved it? Did they re-sleeve a 4 holes or just 1 or 2? I know there is a big difference in power in my car going from march temps to June temps.... my car goes from roasting the tires on a 2nd gear roll at 40 to barely making a chirp now.
It was cold here the other night and the car was right back to feeling good like in like march/ November so I know theres nothing wrong with it except hot and humid weather. My car feels like it lost 30-40 Whp when it's 90 and humid...... hell 70's and humid suck too.
I talked to Vince about it and here's what he said
Yeah, the warmer weather kills the power on these cars. It’s this time of year that LNF owners start calling me up and asking what happened to their tune
So your not alone .
Old Jun 23, 2011 | 01:29 PM
ford's Avatar
They did such a long list of things to your car that it is hard to know where to start. So many silly nuisances can arise from putting a car back together. I have seen cable driven cars put back together and the throttle body not open all the way and it felt underpowered, stupid things like that.
I would still recommend your own compression test just to be safe and to get readings from it. You are tuning the car so do you have any logs, AFR, knock or anything else to give us?
Old Jun 23, 2011 | 02:04 PM
USAMPDUFFY's Avatar
I'm not physically tuning it myself, I just upload Vinces'(Trifecta) tunes with my cable and computer...I'll have to datalog and check it I guess...I have no idea how to work on the SS's...lol...if this was the good ole' base model itd be all good.
Old Jun 23, 2011 | 02:14 PM
cubaniche's Avatar
Yeah the heat here in TX this whole summer has been killer. I can notice a huge power dif during the day to the night time when its slightly cooler and not as humid.
Old Jun 23, 2011 | 11:02 PM
USAMPDUFFY's Avatar
Vince from Trifecta just shot me an email, apparently my power loss is all heat soak, which like I said earlier is plausible, I havent been home to see a gradual power loss with the rising ambient temperature...I just hope they have E85 in Ft. Riley, KS.....and I guess Ill just get a zzp intercooler and devilsown meth if i continue to have issues.
Old Jun 24, 2011 | 07:42 AM
Yeah he forgot to mention that he had reflashed the tune back after getting the car back from the dealer so I sort of assumed the obvious due to lack of info.... I probably just misunderstood what he was saying
Heat soak huh? Sounds like you should get in on the ZZP IC group buy going on. The deal is too good to pass up..
Old Jun 24, 2011 | 09:37 AM
cubaniche's Avatar
This makes sense. Glad its just summer time heat and not the engine man. I hope to be going to an E blend here soon. This turbo is nice and pulls hard on 93 but I want the timing that E gives me, back.
Old Jun 24, 2011 | 10:26 AM
BYT*SS*TURBO's Avatar
I didn't think it was THAT hot in WV...
Old Jun 24, 2011 | 10:34 AM
Gremlin85's Avatar
What BYT said...
I know heat and humidity can make the car feel a little sluggish... But I think maybe you might be a little over sensitive with the feeling?
Old Jun 24, 2011 | 10:35 AM
ford's Avatar
YouTube - ‪Nelly - Hot In Herre‬‏
Suck it biches!!!! Some Nelly for you all!
Old Jun 24, 2011 | 10:42 AM
^^ god damnit man.. that's the last thing I need to hear in the morning!! lol
Old Jun 24, 2011 | 10:44 AM
Originally Posted by Gremlin85
What BYT said...
shhhhhhhhhhhh... I'm trying to get more people in on this group buy! You're killin my mojo guys!
Old Jun 24, 2011 | 10:47 AM
I could see him saying that about AZ peeps but not WV lol..
Old Jun 24, 2011 | 10:48 AM
CobaltVenomSS's Avatar
time for some meth injection
Old Jun 24, 2011 | 03:01 PM
USAMPDUFFY's Avatar
I'm ordering my ZZP FMIC on the 1st and ill see how that does, I'll be looking into the E85 tune as soon as I get there....assuming they have the fuel...is it possible my car just isn't "broken in" still? I've only ran it about 1200 miles since the rebuild...
Old Jun 24, 2011 | 06:21 PM
Gyrocon's Avatar
how did you melt the head? did you max out the HPFP running E?
