Pretty sure piston 4's rings are gone
That does read like a boost leak having a lean idle and rich under other circumstances ( hence the very negative LTFT) like under boost. Having a BOV after a MAF is never ideal IMHO even with a "ECP" Tune. It could be leaking a little at times and not at others. Go back to just the BPV and see what happens to the fuel trims. Which intake do you have again?
make sure everything is tight and lined up then double check the cam timing by rotating the engine with a wrench to make sure nothing moved and is still bang on before trying to start the engine
Poor college kid though...
I'm thinking pistons, rods, and bearings then get it running. There's no reason that won't work without touching the head or timing at all, right? I know this isn't ideal but it minimizes the amount of stuff that can go wrong if I run into a problem with it all back together.
I'll clean the valves later this summer if I still have the car.
LDK short block is 1500+250freight,you'll have to mess with timing. LDK longblock without turbo is 3600 +250freight but you have a brand new engine. You said the previous owner beat on it and at least toasted the rings on cylinder 4, the cylinder wall could be screwed also.
If you drop another 4k on the engine you'll have another 100k+ miles out of it, so if you plan on keeping the cobalt for awhile you're not going to get dick for it with a blown engine
What bov were you running?
The zzp bov. I may try bov again some time but I'm gonna buy brand name one if I do. Right now I need to take this out of the equation so I can get my car running right. So I'm taking this potential issue out of the equation
I wouldnt think a new piston/ring pack would seat without honing the cyl walls, and to do that, the engine would have to be out of car and disassembled. The piston and rod would have to come out thru the top of the engine.
