Problem Need Help!
Old May 16, 2010 | 02:19 PM
Spooled's Avatar
Problem Need Help!
Ok i just received the GT tuner from Trifecta yesterday and today i loaded the tune up and it went very smooth with no problems, i went on a test drive afterwards turn the traction control off and i get on it in 2nd and im only building about 10-11 psi of boost? Turn it back to stock mode and im only building the same amount tried it with the cruise control button on and didnt change anything, open the hood and check for any leaks and couldnt find any, so i get back in the car and so the same now im only building about 3-4 psi. Could you help me out and let me know what could be going wrong id try to contact Vince but they are closed Sundays.
Thanks, Dustin
Problem solved called Trifeca and Vince was actually there and we got the problem fixed! Great guy btw!
Old May 16, 2010 | 02:36 PM
D-mac's Avatar
Thanks, Dustin
Be nice to share the answer for people
Old May 16, 2010 | 03:29 PM
Younggunna's Avatar
maybe he didnt hit it twice to go into competitive mode, cuz thats how my selectable tune is activated
Old May 16, 2010 | 04:52 PM
tomj77's Avatar
ya u have to hit it twice. just going to traction off doesnt turn on tune u have to go to competitive mode.
Old May 17, 2010 | 10:35 AM
Spooled's Avatar
Sorry it was that exact thing lol i felt so dumb and also i installed a block off plate before the tune and it didnt come with directions so i thought it was just take the tan one off along with the spring and the rubber piece if the BPV but Vince said i would need to install the rubber piece back on there (stupid me) because that properly blocked it off, and everything was fine after that. Now just got to data log and fine tune
One question???? iv read on some threads that if you go get the car dynoed in competitive mode it will not work right, so how can i do it if the tune only works in that mode? Would i have to get Vince to switch it to just traction off instead of it being activated in competitive mode.
Old May 17, 2010 | 12:09 PM
umrdyldo's Avatar
pretty ESC needs to be off for correct dyno.
your tune should be active when ESC is off.
Old May 17, 2010 | 12:58 PM
SeanEE89's Avatar
Competitive Mode leaves ESC control on. To disable that you have to hold the traction control button down and it'll relay in the display when it has been disabled. I could be wrong, but I think No Lift Shifting is disabled when ESC is turned off as well.
Old May 17, 2010 | 01:19 PM
kidcrash603's Avatar
For dyno pulls press and hold the traction control button until ESC OFF is displayed on the DIC. Your tune will be active.
Old May 17, 2010 | 02:15 PM
Spooled's Avatar
O ok thanks for the info guys
Old May 18, 2010 | 03:47 AM
SSlobalt's Avatar
That was awfully nice of Vince to diagnose that problem for you.
Old May 18, 2010 | 09:36 AM
Spooled's Avatar
Yea it was because the business days there are mon-fri and he answered on a Sun and helped me out. weird guess he was there doing something and just decided to answer the phone when i called, guess you could say i got pretty lucky.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
