Problems
It will still make full boost if its a small leak and you risk blowing the turbo from over spooling it. My car had no problem holding 26psi when i had a boost leak but the power felt laggy.
Funny, thats exactly how my car is..when term tuned my car, it was awesome and pulled like a ****, then everyday it was slower and slower. Then i went to the track and only trapped 107 and ran a 13.2 on a perfect run, then i knew something was up...
We say it all the time because it's true most of the time: boost leaks happen a lot. Being able to test for boost leaks on a turbo car is an absolute must. It's just that common. Don't get too down on your car. You got it for a good price. Thrown the clutch and IC on the credit card and keep driving.
i know this might not be your problem but i had a similar issue and replaced my evap purge solenoid and it ran better.
also how many miles are on your plugs? i just had a set of the ngk 3787 and they started fouling out after 10k miles. i just ordered a new set of ngk stockers and threw them in and its better once again.
i have 45k miles and i feel like you do sometimes lol (even have slipping clutch) but i just ordered a zzp stage 4 clutch so it looks like im stuck with the balt. now all i need is install money
You could have bought a ky stage three or four and still had quite a bit for installment fees..
na... didn't burn it up... let's just say everyone that bought one in my area.. about 10+ had to replace them with diff ones.... and the performance shop I went to... took 3 hours to do it so lol pretty much the pressure plates are garbage.
Lol ^ pressure plate they used to use is the Sachs pressure plates which is the stock lnf plates.. lol... So calm down there. And also fact is we don't use those plates any longer...
It looked a lot harder than doing one on a honda, which is the only experience i have with clutches...i'd rather have it done right, then second guess myself and be bloody knuckled...lol
Ky stage 3 clutch with throwout bearing 475 shipped and order a boost leak tester from modern performance for like 20 and you can do the clutch yourself its not that hard aslong as your kinda mechanically inclined
I went 74k on my clutch before it went its all about how you drive/shift properly and that's with A LOT of racing and yea I know a lot of people gonna think I got a lot of miles but I DD my car and done like 8-10 trips to nj and back plus a lot of track and street racing
Yeap, exactly how my car got after a few weeks of owning it. Later found my MPx intercooler would get pushed back when my front end would scrape due to being lowered and it was cutting slits in my silicone couplers where they would get pushed against the sharp seam of the unibody frame.
so before i was able to do my boost leak this morning, i blew the charge-pipe completely off. I have no reason why it came off again. I am using the ZZP hot pipe with the stock rubber couplers with them, but they are just not holding on with full boost...
after i took everything off and completely re-installed it to as tight as possible, it seems to be okay right now. I also reset the ecu because it instantly started idling worse than before, so i will drive it around the rest of the day to make sure all is good...i can't tell for sure, but it sounds louder around the turbo than before, hopefully it isn't shot too....the clutch is still shot though..2nd and 3rd is gone
