Problems shifting quick with the Exedy
Old Apr 30, 2010 | 10:47 AM
MaxVQ35DE's Avatar
Ok so the exedy has been great, however occasionally when WOT, shifting near redline (Not NLSing) i will get a grinding type noise that i DO NOT feel in the shifter. This happens into 2nd and 3rd on "quick shifts that I never had problems with on stock clutch. Under all other conditions, the shifts are as crisp as brand new, if not better. I have a hard time thinking is synchros because way back when i remember grinding into 5th while cruising and i could feel it in the shifter.
Now ive got some variables since i was stock
Exedy HyperSingle... about 1600 miles
OTTP Stage 2 mounts? Anyone else experience shifting issues with these?
I have adjusted The Shifter position already, still does the noise
Clutch install learn was done one the Stock/OEM ECU, Car is operating on Tuned 2nd ECU
If anyone has any input, so i can narrow it down before i take it back to the installer?
Thanks
Old Apr 30, 2010 | 10:55 AM
maybe clutch needs to be engaged all the way to the floor at WOT
just an idea
Old Apr 30, 2010 | 10:58 AM
MaxVQ35DE's Avatar
the clutch takes up about half way thru travel, i do depress the clutch fully for every shift.
Old Apr 30, 2010 | 11:11 AM
BYT*SS*TURBO's Avatar
Look into the adjustable clutch rod mod
Old Apr 30, 2010 | 11:25 AM
MaxVQ35DE's Avatar
have it, but which way to go with it?
up or towards the floor?
Old Apr 30, 2010 | 11:50 AM
Iam Broke's Avatar
Up, so the disc seperates farther when depressed to the limit. The cyl bottoms out on mine before the pedal hits the carpet. My SPEC still drags a bit at times. Wishing I had got the ZZP stage 4+ and kept the stock FW myself.
If the cyl is bottoming out, short of vac bleeding it to make sure the air is all out (I did 3 times) it is what it is. Doubleclutch.
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 07:39 AM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
