sputtering, backfiring, and misfiring
Old Apr 28, 2010 | 11:51 PM
kretty's Avatar
OK, here is my issues... I NLS'd today and missed the gear. i revved high but hit the limiter. after that, my car started misfiring just as it would on a cold NLS. i shut it off, tried restarting it, but no change. sounds like a subaru. popping backfiring and misfiring. i changed the sparkplugs, gapped them to manufacturers specs. i have recently put a catless DP on. I'm getting p0107 code. also there is a lot of liquid in the exhaust, doesn't smell like coolant or gas, but there is a lot of it... whats wrong with my car? i posted this in a few places so....
anybody?
Old Apr 28, 2010 | 11:53 PM
elite_Cyborg's Avatar
does it smoke?
Old Apr 29, 2010 | 01:40 AM
Stamina's Avatar
See my reply to your post in the other thread:
https://www.cobaltss.net/forums/show...4&postcount=38
Old Apr 29, 2010 | 08:37 AM
kretty's Avatar
Doesn't smoke, its on its way to the dealer to get looked at.
Old Apr 29, 2010 | 09:46 AM
BYT*SS*TURBO's Avatar
^This
Do you have the RPD?
Old Apr 29, 2010 | 09:50 AM
Supercharged Guy's Avatar
Dont misss a gear and you wont run into that problem..lol
Old Apr 29, 2010 | 09:56 AM
ctn2mb's Avatar
r u tuned... cause if so mine does that even if its warmed up... well doesnt throw that code lol mine throws a misfire code
Old Apr 29, 2010 | 11:24 AM
efactor's Avatar
had someone with a similar problem sounding like a Subaru including the misfiring, but nothing dealing with the NLS. He busted his intercooler once and replace it with a PVC pipe temporary. Then his mom put 89 Octane in his fuel tank, after all that on his birthday ready to go to SC to visit a couple of friends. His car wasn't the same again. Done all straight pipe w/o sensors, driven it hard most of the time like he stoled it, and replaced his spark plugs, but nothing was ever change. Now it sounds like a Subaru, but he got rid of it a long time ago before I gotten my 09 SS/TC.
Old Apr 29, 2010 | 11:35 AM
Permafried-'s Avatar
This is good to know .
Old Apr 29, 2010 | 11:54 AM
Terminator2's Avatar
anybody?
P0107 is a map sensor low voltage code. You blew the map so the fueling is all screwed up and the car is misfiring. The fluid you are seeing is likely water from the combustion process.
Old Apr 29, 2010 | 04:35 PM
kretty's Avatar
so, ended up blowing the map sensor, boosted to 43lbs and threw a few rockers, everything is being covered under warranty. what a ride. lol i knew the pop i heard wasnt a good one.. haha, gettin her back 4-30-10. cant wait.
Old Apr 29, 2010 | 04:40 PM
SSlobalt's Avatar
Holy cow! Both for the blowing of it and the fact that they are covering it under warranty.
Old Apr 29, 2010 | 04:43 PM
kretty's Avatar
my dealership takes care of me. puttin the DP on tomorrow again. lol
Old Apr 29, 2010 | 04:44 PM
pantherqs's Avatar
Exact same thing happened on a friend of mine's SS/TC about two weeks ago. Missed a gear, and busted his rocker. Odd. How do you know you hit 43lb's? Cause that ain't happening on the stock map's readout wise. And yeeeeah.
Old Apr 29, 2010 | 04:48 PM
I dunno because even if he is talking 43 lbs absolute pressure that is still 28.5 lbs guage pressure.
Old Apr 29, 2010 | 05:07 PM
SSlobalt's Avatar
Maybe he has one of those aftermarket gauges that captures peak boost. Just speculatin'.
Old Apr 29, 2010 | 10:01 PM
kretty's Avatar
That's what the tech said he read from the computer... I dunno. Sounds kinda high, I'm just relayin info... It will be back on the road tomorrow. It'll be catless again soon as well.
Old Apr 30, 2010 | 11:28 AM
kretty's Avatar
any idea if the catless DP is causing problems? im assuming not because almost everybody has one....
Old Apr 30, 2010 | 12:22 PM
Nope.
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jcarroll53
Sep 24, 2015 07:43 PM
OrangeK
Sep 20, 2015 03:02 AM
