Psykotuned LNF
Old Aug 19, 2008 | 06:30 AM
  #76
IsItFast?'s Avatar
Originally Posted by Psykostevo
Interesting. Never heard of that. I know on one of the cars we did for "Fast and the Furious 4" we put 4 interceptors in there LOL! 2 on the drivers pillar and 2 on the passengers pillar facing the driver.
How did they pull that off? The most you can get from Aeroforce is a 3 gage set, and that reads slowly as they are all polling for data, and is a custom order
Originally Posted by PimpLay2
2 parameters on 4 screens... and that just gets annoying because they change like every second
You can change the timing of how long each displays for. I prefer the static display on mine. I have the two gage set (first 08 cobalt SS with aeroforce gages in it!). When you put them into record mode they record all the sensors you have it set up for, so you can scroll through frame by frame on each sensor, then switch sensors, and do it all over again. IAT2, knock retard, misfire, WB02 being quite important
No kidding on how lean the direct injection engine runs. It holds around 14.7 and even goes over 15 near wot! When I was at the dyno, the operator almost shut it down for running so lean, until I mentioned that DI runs much leaner.
Old Aug 19, 2008 | 06:36 AM
  #77
SCBLKRL's Avatar
looks good steve
Old Aug 19, 2008 | 11:48 AM
  #78
Area47's Avatar
Rent me! per hour
hmmm. the illusion of torque comes full circle.
Old Aug 19, 2008 | 11:55 AM
  #79
Omega_5's Avatar
Not everyone plugs their Interceptors into the OBD2 port...
I have 3 interceptors... in total, only 3 parameters are from the ECU. The other 3 are analog inputs.
Old Aug 19, 2008 | 01:20 PM
  #80
IsItFast?'s Avatar
Ahh.. I forgot about the 2x analog inputs per gauge!
Old Aug 19, 2008 | 01:50 PM
  #81
Area47's Avatar
Rent me! per hour
still no mail
Old Aug 19, 2008 | 01:58 PM
  #82
Psykostevo's Avatar
Originally Posted by Area47
still no mail
You do now.
Old Aug 19, 2008 | 11:04 PM
  #83
steddy2112's Avatar
That is all.
Old Aug 20, 2008 | 10:38 AM
  #84
Area47's Avatar
Rent me! per hour
i was going through the hpt file last night. i thought there was going to be a lot more tables to deal with than that. thats kiddy **** right there.
maf, 4 timing tables, pe. seriously? thats it?
steve, you sent me a stock file correct?
Old Aug 20, 2008 | 12:09 PM
  #85
Psykostevo's Avatar
Oh, that wasn't stock. But yeah these cars are really sensitive to changes you make, but there's not much to them.
Old Aug 20, 2008 | 12:36 PM
  #86
nhanson's Avatar
looking at this thread makes me want to buy a TC....
  #87
Area47's Avatar
Rent me! per hour
mmm, interesting. i take it you have a stock file somewhere? guess i need to get a hold of a ss/t for a day and tinker with it
Old Aug 20, 2008 | 12:37 PM
  #88
Psykostevo's Avatar
Of course I have stock files. They just take 21 mintues to scan off the car :-(
Old Aug 20, 2008 | 12:39 PM
  #89
Area47's Avatar
Rent me! per hour
i personally think the hpt people need to get with the program. i know for a fact there is a lot more tables that what is being given.
Old Aug 20, 2008 | 12:40 PM
  #90
Psykostevo's Avatar
Well duh! They are just in the Beta phase anyhow.
Old Aug 20, 2008 | 12:56 PM
  #91
foff667's Avatar
Post up some numbers when you get it on a dyno!
Its amazing what just a few tweaks here & there can net with these pcm's, similar to how you can make gobs of hp/tq on diesels.
One of our tunershops just made upwards of an extra 65ftlb & 30hp with just tuning alone on their test solstice gxp so there is tons of power to be made.
Old Aug 20, 2008 | 01:03 PM
  #92
Area47's Avatar
Rent me! per hour
i wouldn't worry too much on the injector control, due to the whole lack of upgraded injectors. the timing tables seem a bit small for ultimate control. im not worry about dwell timing because these things are like ls1 coils. they can fire through a bucket of water.
i knew i should have brought my laptop to work today
Old Aug 20, 2008 | 01:30 PM
  #93
Psykostevo's Avatar
I have 1 solstice, 1 sky, and 1 cobalt going on the dyno this saturday. The Sky is an auto, and both other cars are manual.
Dude, the stock injectors are only running at 35% even at 22.5psi. I don't think there is a need for an upgraded fuel system. Plus with that config I sent you you can see each individual injectors IDC.
Last edited by Psykostevo; Aug 20, 2008 at 01:30 PM. Reason: Automerged Doublepost
Old Aug 20, 2008 | 01:54 PM
  #94
krispy's Avatar
The high pressure fuel pump will max out before the injectors, thats what you need to look at.
Old Aug 20, 2008 | 02:00 PM
  #95
Psykostevo's Avatar
It is holding pressure so far.
Old Aug 20, 2008 | 02:04 PM
  #96
RedlineBrian's Avatar
Haha.
+infornumberssoon
Old Aug 20, 2008 | 02:09 PM
  #97
krispy's Avatar
Using the flow number for the pump that I found assuming 6000 rpm & .6 BSFC and that the density of the test fluid was the same as gasoline I calculated ~400hp would be the pump limit. Now it all depends where you are making peak power as the HP pump flow rate is dependant on RPM.
Old Aug 20, 2008 | 02:15 PM
  #98
Psykostevo's Avatar
Peak power seems to be coming in at a lower rpm than stock. ~5,000 rpms instead of 5,500. But it still makes way more power than stock about 5,000. Pretty much hits peak power at 5,000 and stays at that level through 6,300.
Originally Posted by steddy2112
That is all.
Please tell me you flashed your car already!
Last edited by Psykostevo; Aug 20, 2008 at 02:15 PM. Reason: Automerged Doublepost
Old Aug 20, 2008 | 02:23 PM
  #99
krispy's Avatar
Well it should be pretty apparent when the pump starts to max out. Find the output for the rail pressure and graph it against ECM commanded rail pressure (I'm assuming there is a commanded rail pressure due to my experience w/ Bosch diesel fuel systems). When the rail pressure fails to meet the commanded then you have a fuel supply problem. (either the HP pump or the LP pump in the tank)
For reference, if the actual pressure is 1500 kpa less than the commanded or the fuel pressure adjustment is out of the range of -/+ 2,500 kpa for 4 seconds you will drop a code. If HP tuners lets you see these parameters you should take a look at it just for your own knowledge.
Old Aug 20, 2008 | 02:31 PM
  #100
Area47's Avatar
Rent me! per hour
wonder if the bigger pump from the spped 6/3 cars would work
