Pte 5831
Pte 5831
Anyone have any experiences with the PTE 5831 MFS turbo??
Looking at the Treadstone Stg4 kit and thinking i might try this turbo. I have noticed that some SRT's run this particular turbo. Thanks in advance
robk
robk
hopefulley you have a grinder or a shop install the turbo manifold... every single one ive installed.... about 6 now the manifolds need to be ground to clear the water neck and the runners need to be clearenced on 2 and 3 so you have room to get the socklet on the bolt.
just a heads up. personally i would do a 5558 ove that turbo
Comp Turbo - Billet Wheel CT3-5558
Yep, comp is very good company.
I just got my 6465 triple ball bearing and billet wheel turbo. Oil cool only so no need for extra coolant lines.
Thanks again everyone
robk
This turbo is way way to big to be put on a 2.0L. It's rated at 900hp lol, This is going in my 335i. I'm ripping out the twins and doing a single top mount.
Anyways, I think comp is a good choice. Gives all the goodies you'd want in a turbo for almost 1/2 the cost of other companies... BW, Garret, PTE.
robk
The 58 is the inducer of the comp wheel. The 31 is one of their stage 3 turbine wheels which has a 57mm exducer. Now its not the exact same wheel as the one in the 5857 as im sure the inducer is different but it gives you a pretty good idea. The wheels are matched. A 58mm comp is gonns flow 50-54lbs and the stg 3 turbine offers good spool time and capabilities of 500-525whp. Its just a less expensive turbo without the ported compressor housing. Im pretty damn sure you'll be happy with it if youre good with 500-525whp
True but i was referring to what he could get out of the turbo. And sometimes i forget not everyone throws another fuel rail with 4 38lb injectors and a 450lph pump on their lnf like me so.... Lol
robk
Op, I was also searching around the forum on a turbo setup.
http://www.maperformance.com/comp-tu...ger-550hp.html
That turbo with a treadstone manifold.
Get a custom d/p and dump tube made
Get a recirc bov
Buy your own wastegate
Could save some money that way.
Get a recirc bov
