Questions about ZZP catless downpipe.
Old Jul 8, 2015 | 12:45 AM
footballplaya3k's Avatar
Catless is good if you want your car to both sound and smell like ****. You will NOT make more power over a high-flow setup. There are 700hp factory cars that have cats, your ******* Chevy Cobalt is not going to benefit from not having one. I've had so many different exhaust setups over the years that I'm not even going to bother arguing any further with you noobs.
HOWEVER, if you do insist on not listening and going Catless on an LSJ car, I HIGHLY RECOMMEND you use some sort of silencer in the exhaust to combat rasp.
700hp factory cars have cats because they're required by law, quite a dumb statement. Have you seen the power gains from removing the cats? You might want to find out before you run your mouth.
Old Jul 8, 2015 | 12:57 AM
Yeah catless makes more power but its not something huge
Old Jul 8, 2015 | 01:12 AM
chris88z24's Avatar
Ricers ITT.
Old Jul 8, 2015 | 02:39 AM
ForceFedDork's Avatar
... good stuff. Good entertainment here.
Old Jul 8, 2015 | 03:31 AM
Ricers ITT.
Old Jul 8, 2015 | 06:19 AM
You do realize this is the lnf performance section? Go back to your lsj area
Old Jul 8, 2015 | 07:17 AM
SR Tech's Avatar
Just for the sake of the argument, while I have no dyno sheets to prove anything... I noticed zero difference other than sound and smell when I switched from my ZZP catted to my ZZP catless. While I enjoy the sound it smells awful. Don't know if the ethanol is partly to blame but it's pretty bad
And to get back on topic, I haven't had to turn any codes off with the catless/angled bung. I had the angled bung on my ZZP catted and I would actually throw post cat lean codes (p2096) every so often.
Old Jul 8, 2015 | 01:24 PM
chris88z24's Avatar
Exactly. The stock DP is "restrictive" with two cats, but even then it's only a couple of HP you're going to gain. If you think it's worth it to have a technically illegal car that smells like ass and sounds like a beehive then you're a ricer.
Old Jul 8, 2015 | 01:36 PM
Little fyi, even a hi flow is technically illegal.
Also LNFs don't sound like LSJs when you remove the cat
Old Jul 8, 2015 | 05:02 PM
SR Tech's Avatar
It sounds really nice with just the catless dp and stock "cat"back. I'm sure on lsj's it gets very raspy. Turbos act as a muffler in some sense
Old Jul 8, 2015 | 05:06 PM
  #36
Dipped_Cobalt's Avatar
lol
Old Jul 8, 2015 | 11:30 PM
  #37
crispino's Avatar
I have a Catless with the angled bung from zzp and throw a cat code now.. overall I'm very pleased, but if you're tuning then don't spend the extra mone. I tuned my 02 sensor out, so no more code. Wish I would've known before the extra 40 bucks or what not haha
Old Jul 9, 2015 | 08:08 AM
  #38
hawkssoccer11's Avatar
idk why your throwing a code, ive been running catlees now for over 3 years and mines from turbo xs with an angled bung. you might have other issues there my dude
Old Sep 6, 2015 | 08:41 PM
  #39
2000Firehawk's Avatar
The 2nd cat is restrictive, & should be 'cored', or replaced with a high-flow,high-volume cat.
The 1st cat is fine, & helps low-speed response, & doesn't hurt top-end power.
My last time at the track, I ran 12.3s all day, with a HHR SS automatic, at 1,200'.
I've tested many DP setups, at the track, & the stock DP, with a 'cored' 2nd cat, works best,
with a stock K04 turbo.
I'm also running the stock intercooler, & hot/cold pipes.
Old Sep 7, 2015 | 07:34 PM
  #40
no_ss's Avatar
Yeah same here and mines been on my car for 1000 miles and it just threw the code. Oh well, they can't all work I guess. It says MAY prevent an engine code.
Old Sep 8, 2015 | 01:41 PM
  #41
my car now has 101k on it and 80 of that has been cattless not once have i thrown a code and im running a turbo xs catless dp.
Old Sep 8, 2015 | 01:49 PM
  #42
Turboxs FTW I have the chatted one but same no code in 1 yr
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
