Quick question
Old Aug 30, 2014 | 12:31 AM
Behaviorz's Avatar
Quick question
So I just bought my 2010 Cobalt SS two weeks ago. I ordered the K&N intake and zzp cat less downpipe. I'm going to get tuned next, but from what I've read I need the GM Stage 1 sensors. Are these all I need and do they just plug right in? GM ACDelco - GM Stage 1 Sensors #
Old Aug 30, 2014 | 12:42 AM
andrewcarr1993's Avatar
Yes those are plug and play but it won't run right (if at all, not sure on that though) until it's got a tune for those new sensors.
Old Aug 30, 2014 | 12:57 AM
Behaviorz's Avatar
Yeah I won't be installing the downpipe or sensors till I'm ready to be tuned. So can I just order a tune from Trifecta like I did with my other cobalts and they send the black box and just plug it in and flash and send the box back? Or do I need to get some cord and use a laptop like I've heard.
Old Aug 30, 2014 | 02:32 AM
tomj77's Avatar
all depends what tune u get weather u need the new sensors or not. up to 22 psi u wouldn't. anything trifecta u don't need em really. hp tuners ull need em
Old Aug 31, 2014 | 09:17 PM
Behaviorz's Avatar
I'm going to be doing Trifecta for the tune. So your sure I don't need the new sensors with Trifecta? If it's better to just have the new sensors I will just buy them. I was thinking about running e85 since I live in Minnesota and there a ton of gas stations with it. What do I need besides a tune to run it and is it safe to run long term or can running it cause issues down the road?
Old Aug 31, 2014 | 11:35 PM
footballplaya3k's Avatar
It's up to you. If you want to be as safe as possible and don't mind spending the money, then ya get the 3 bars. But many people run the stock sensors fine with a tune.
Old Sep 1, 2014 | 12:54 AM
nathan112i's Avatar
i was on 23psi on stock map sensors with trifecta, i am not sure how trifecta is with e85 but on 94 octane he left a ton of power on the table
Old Sep 1, 2014 | 01:12 AM
Behaviorz's Avatar
Ok, I just ordered the Injen charge pipe also. I think I'm just going to buy the sensors to be safe or ready for if I decide to get a bigger turbo. Can I put on the intake, cat less downpipe before getting tuned or will the car run funny? And is a tune the only thing I need to run e85? Appreciate the responses
Old Sep 1, 2014 | 09:40 AM
nathan112i's Avatar
you can put the intake on but i would get a tune shortly after just to make sure long term fuel trims are in check, your catless dp will most likely throw a check engine light after a while before you get tuned
Old Sep 1, 2014 | 10:53 AM
Behaviorz's Avatar
Ok thanks bro, that's probably what I'll do till I get tuned. So does anyone know about running e85 on the lnf? I know the lsj needed 80lb injectors to run it just not sure if I need anything other then a tune to run it? And do people run into issues running e85 over 93 octane?
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
