race gas
I dont mess with my trims, I set it and forget it. My car is a daily driver and getting another 5-10 hp seasonally is not worth it to me. I am finding less and less time to with work and family to be with my car. I wish I had the time to do that.
I use unleaded 100, and I actually use abuot 50/50, half 100, half 91 so it makes it a tad cheaper. It makes just as much power if not more than cars tuned for E-85. I did it mainly for the knock resistance, as my car doesn't really see any at wide open throttle ever since being tuned for higher octane. That white car though uses C-16...lol.
e85 will make more power in the lower rpm's then race fuel because of the much slower burn rate
pump e85 is inconsistent on the blending most e85 is blended at the pump not to mention just because the pump is marked 105 oct dose not mean that is what you are getting a 105 oct e85 is all over the place on the octane rating
e85 requires extra money spent on a fuel system
race fuel has excellent at resisting knock and pre ignition
race fuel will out power e85 at any given octane in the upper rpms due to the increased burn rate
race fuel no big bad fuel system needed
race fuel is blended for a specific purpose and will trump e at any given octane but if you are one of those that have to have e85 then be smart and buy a race blended E85 or 98 it is still cheaper then race fuel and you will always know what you are putting in your tank
But if you are willing to learn something this site has actual results not forum dribble to back E85 up. Here is the link and below that here is a snippet of race vs E.
What You Need to Know About E85 Ethanol Alternative Fuel - Hot Rod Magazine
To simplify the test, a BigStuff3 engine-control unit with both pump gas and E85 calibrations handy was plugged into the EFI harness. On 100-octane gasoline, the combination made 509 lb-ft of torque at 5,200 rpm and 540 hp at 6,000 rpm. (W2W tests its pump-gas engines on 100-octane for safety's sake, then performs its final validations with 93-octane pump fuel.) With no other changes except in the software calibrations, on E85 the engine made 524 lb-ft of torque and 546 hp. So the numbers were very similar for both fuels, with E85 squeaking out a slight edge. The real difference here, of course, is that one fuel is an expensive racing blend while the other sells for less than regular. And Urban felt that with some optimizing of the spark curve to exploit E85's greater octane, further gains were well within reach.
This!!! The extra oxygen provided by E-85 makes more power vs race gas (non oxygenated types of course) even if the octane is about the same. More oxygen means more power!!! E-85 is just like injecting a small shot of nitrous oxide on top of running running 110 octane gas (oxygen again here). The only disadvantage to E-85 is 27% greater fuel mass required to have the same btu output (energy content) as gasoline.
