Random loss of boost, restart cures it.
Old Sep 30, 2011 | 09:29 PM
Joe Schulte's Avatar
Second time this has happened, both similar in scenarios, cruise control set to 80 cruising down the highway and I feel it happen. Just a slight drop in RPM's I imagine, but something tells me.
I put a load on the engine, won't go into boost, RPM's will climb, no CEL, runs fine, just literally says to hell with me.
Both times I've shut the damn thing off, started it up, and it's been fine.
Anyone?
Old Sep 30, 2011 | 09:34 PM
ramrod1337's Avatar
Won't go over 5lbs? What are your mods?
Old Sep 30, 2011 | 09:55 PM
Won't go into boost at all, shut it off, start it back up and all is good again.
Intake/DP/tune, nothing crazy.
Old Sep 30, 2011 | 11:25 PM
Wangspeed's Avatar
It's throwing codes, you're just not reading them. Likely a leak, or your intake is causing the MAF to get wet, either directly, or indirectly through condensation. I had the problem til I covered my Hahn intake with a K&N drycharger.
Old Sep 30, 2011 | 11:27 PM
Chevycobaltss3's Avatar
Sounds like limp mode. If no cel vince coulda disabled it. So u could be getting anything.
Old Sep 30, 2011 | 11:41 PM
raver0789's Avatar
How many clicks on the motor?
Old Sep 30, 2011 | 11:49 PM
zrated89's Avatar
its the trifecta toon joe just kidding sounds like a leak somewhere or maf getting wet as stated, weird though where yours sits i doubt its that
Old Oct 1, 2011 | 09:38 AM
46k on it, and with my intake location I don't find that possible either.
I do have a code reader, though I doubt it'll pull anything without a physical CEL, I'd have to borrow the one at work for that.
Old Oct 1, 2011 | 09:45 AM
PenguinPIE's Avatar
Throwing a code doesn't necessarily throw a CEL so give it a try
Old Oct 1, 2011 | 09:52 AM
No codes shown, sure work scanner can pull a history.
Old Oct 1, 2011 | 10:40 AM
The thought of this being a bypass valve issue made my Dejon spring cross my mind.
Found some bashing of the spring after I had ordered it, but for the ease I installed anyhow and never had any of the issues people listed. Nice, crisp hold of 22psi but now I'm wondering if that's a possibility here.
I've been meaning to buy a Forge, but haven't made such a priority.
Thoughts on this being a Dejon spring/BPV issue? I'll fully admit guilt there.
Old Oct 1, 2011 | 10:49 AM
umrdyldo's Avatar
Maybe go back to stock spring to see if you can fix the issue.
Old Oct 1, 2011 | 12:32 PM
Ch1ck3n's Avatar
5lbs limit is a limp mode. Make sure you check your overboost protection, if the car hits the limit it will limp the car until it's restarted. Had an issue with it on one of the lnf's I tuned, turned up the upper boost limit and fixed the problem.
What kind of map sensors do you have?
Old Oct 1, 2011 | 08:21 PM
Still on stock sensors, tried finding solutions to not hack my factory wiring, sold my GMS1 sensors, than a week later CED comes out with the pigtails. Go figure, after 3 years.
Made 17 1/4 mile passes today with no issues, hell I've only had this happen 2-3 times cruising on the highway. Retune to come for Spring, with some changes and probably leaving Trifecta so we'll see I suppose.
Old Oct 2, 2011 | 06:01 PM
FRQ FLYR's Avatar
That sux about the sensors/pigtails; was wondering which you were running as well.
I had a similar low boost episode that would occur every other startup it seemed; I assumed pigtails or dirty sensors. Dealership cleared non-specific misfire codes yet problem reoccured. I cleaned my MAF and (re)installed my Forge bpv which had been removed for a time due to a dealer visit; 1st startup produced lowboost then it righted itself and has been "right" for several months now.
Old Oct 2, 2011 | 09:36 PM
Threw a MAF code today! Symptoms the same, so I reset the ****** on the highway and cured instant. Time to look deeper!
Old Oct 3, 2011 | 05:35 PM
Ch1ck3n's Avatar
You might have a small boost leak somewhere or a dirty maf.
Old Oct 3, 2011 | 10:05 PM
raver0789's Avatar
I can almost bet its dirty valves because of the buildup. Can can't make the proper boost all the time, goes into limp mode.
Old May 9, 2019 | 12:06 PM
Michael Malignaggi's Avatar
help
Anyone?
Did you ever fix this? I have the same issue. It losses boost and than pull over restart the car and it comes back again. no check engine light. very random but happening more than often now?
Old May 9, 2019 | 03:56 PM
This thread is over 8 years old.... he is LONNNNNNG gone
side note... his car was one of the nicest cars around at the time. OG
Old May 9, 2019 | 04:02 PM
I know its a old post.. I was hoping he would get some notification and maybe reply to me helping me... Same exact issue that has been happening with me for months and trying everything.
Old May 9, 2019 | 04:46 PM
Kolt's Avatar
Only by pm would he get a notification if he set up his email to get it. Otherwise your gonna be out of luck. He hasn't logged in in over a year
Old May 9, 2019 | 08:00 PM
tomj77's Avatar
I also say maf. I blew the fuse for maf and it did same crap. Wouldnt build boost. Ran super rich.
Abusch500@gmail.com
May 23, 2019 08:43 PM
vjoel2011
Oct 2, 2015 12:11 PM
sick_ss/sc
Mar 25, 2012 09:27 AM
lebulbe
Nov 1, 2010 03:16 PM
boostking
Jul 23, 2009 10:02 AM
