Really need the cold side?
From what i'v heard from a people on here and even a vendor or 2 we dont need to really replace the cold side.. I Was going to go with the injen hot side if anyone can provide enough evidence that i really don't have todo the cold side
my plans for the car is
Intake (Injen already)
Catless or Catt'd DP..
Charge Piping (upper + lower??)
Custom 3" Cat-Back
and a Dyno Tune
trying to keep her the daily driver and keep my camaro
Custom 3" Cat-Back
and a Dyno Tune
I personally would say it's not mandatory, only because I talked to a shop who tested both the HHR SS and Cobalt SS piping on a flow bench vs. both their own prototype charge piping and one currently on the market and found the results negligible.
I think there was a 3-4 difference in CFM between all three. Now of course, there maybe other reasons to purchase is other than airflow (upgraded intercooler perhaps, stock pipe durability vs aftermarket under higher boost, etc.)
i wouldnt switch the cold side for the fact that the MAP sensor is located there and the map sensor has a tendincy to go on our cars (i speak from experience). and having anything aftermarket touching that sensor might make GM a little heistant on giving you a new one.
I changed my cold side and for the pain and hassle you will go through it isn't worth it.... There isn't really any difference between the aftermarket piece and the stock piece and the fitment is tight. If you go through with the aftermarket piece, there is a good chance that you will scratch the powder coat finish off in places....
.to answer questions, it takes about 1.5 hours or so with 1-2 people
I took off the bumper when I did the CPs, but looking back I didn't have to.
The hotside pipe is very easy to replace. I believe we picked up around 6whp on our SS/TC. You don't really need to change the cold side unless you just want a better looking pipe. I went 12.1 in our LNF with the stock coldside pipe.
I discovered a very easy way to position the cold side when I did mine. Whenever you take out the stock hot side (and before you put in the new hot side), route the cold side down the opening and across the front of the engine. That's seriously all there is to it. No need to try squeezing it in from below or the side or anything else. It makes it a piece of cake.
That's good news. How much time we talking here? 1-1.5 hrs to change hot side?
How exactly would you take off the stock lower CP and install the new one without taking the bumper off? Just wondering since I only did the hotside and was debating on cold side. Not worth it to me if the bumper needs to come off. Unless you just buy a new IC and lower CP and do it all at once!
It depends on how you are going to change the pipe. If you use the stock rubber connectors it might take an hour because the stock t-bolt clamps are fixed so you have to cut them off but if you are using all new pc's I would think only about a half hour. It's fairly straight forward. Not a bad gain for such a small amount of work. Plus that stock pipe is def. not pretty.
