rear brakes
#51
I feel everyone on the rear brakes. My driver rear pad actually froze onto the the disk causing a 3mm thick chunk of the pad to shear off. I will wait until GM has some of the pads in though no worries on warranty as my car has only 4600 miles on it. Our rear calipers suck.
#53
There ARE brake parts available if you can't take the noise anymore.
http://ebcbrakes.iwebcat.com
Copy and paste and follow the instructions
And like the other guy said, poke around.
Happy trails
Happy trails
EBC lists the same part numbes (for pads) for both 2007 and 2008. These are not the same brakes. So please stop shedding your knowledge to everyone when you are WRONG!!!!
#54
aren't these the same brake rotors on the G6? the reason I ask is EBCs part # for the front rotors is: GD7265..... the same part # for the 3.5 g6
does that mean the pads would work as well?
#57
Here's the skinny. I had my brakes off this weekend and there is a flaw in the manufacturing process for the calipers. After coming out of the mold, the calipers are supposed to be shaved to 'clean' off the additional metal from the molding process. Some of this metal is was not cleaned and, after enough pad wear occurs, this metal on the caliper begins to contact the rotor. This is why you are experiencing a 'grind' when there is plenty of pad left.
1 of 2 things needs to happen. Either the caliper needs to be replaced with one that is not defective, or you guys will need to pull off the caliper and grind or sand down that portion of the caliper that is or eventually will make contact with the rotor. Without this, you will continue to have the problem no matter what pad/rotor combination you use.
BTW, this should all result in a recall as we clearly have defective calipers on our hands.
#58
this is what pisses me off about GM, the same **** happened with my 2004 Grand Prix GTP, ALL of them that had a moon roof was proned to have leaking around them(and not the weather stripping, water was leaking out of where the moon roof switch was, how I don't know)... It took me like 4 trips to the dealer to get the **** fixed, NUMEROUS people on clubgp had the same problem, and there was never a recall...
GM is bad about not doing recalls on things that are pretty major and yet will do them on stupid crap
#59
#60
**** gm i going to get my car today. i have been carless for a week and im not waiting for gm to get done with there 2 weeks vacation. i ordered pads from over the top performance so i should be getting them b4 christmas. im never dealing with the dealer ever!!!
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
