Recommend me a clutch?
Hey guys, I'm new to the Forum and the Cobalt scene in general.
Picked up a used SS/TC a few months ago and it's on the stock clutch/flywheel. It's also around 125k miles.
I know for a fact I'm going to need a new clutch soon and will be buying a new OEM Flywheel with it. Not going with any Lightweight ones.
I don't exactly know the power estimate for my current mods, but hopefully someone can recommend me a somewhat inexpensive option for a clutch. I haven't had any problems with the stock one slipping yet.
Mod list:
Dejon SRI
Dejon Intercooler pipes
Catless DP
Trifecta Tune pushing 23 peak and 21 holding
I know the stock LNF clutch will work (my driving habits are good, shifting at around 3200-3500 1-2 2-3, never flooring past 3k and rolling into throttle beforehand) but I'd like to know which aftermarket clutch would be the best for this setup.
Mod list:
Dejon SRI
Catless DP
Ecotec LSJ Clutch Upgrade Kit 19212712
GMPP clutch kit, holds more power than it is rated for, and is the best clutch option for stock turbo cars. Even some guys with bigger turbos use it. When aligning the pressure plate cut a standard white bic pen into 3 pieces and stick it on the dowels to help align everything.
Make sure to get new flywheel bolts, as they are torque-to-yield(one time use).
Flywheel Bolt 11570626
Also recommend getting at least the clutch elbow as well.
Ecotec Clutch Pipe Elbow 24252286
It has been used by tons of people with no issue.
It's the go to replacement clutch for sub 350whp
i actually had the gm dealer put mine in when my trans went. they actually called me and asked if i wanted that clutch put in and i said mise well since the trans was under warranty and the put the clutch in for nothing
that clutch works great man you wont have any problems with it
I think it has to do with warranty. Technically there is no GM warranty if installed, but if you have a GM dealer installed it, I doubt you will have a warranty issue with it.
Absolutely, but is the clutch elbow necessary if I'm having no hydraulic/clutch related problems? My catch point on my stock LNF clutch is pretty low on the pedal (like ~25% clutch pushed in) so I don't know if there's any problems.
It's not necessary, but if you're going to be there you may as well replace it, cheap insurance. I went as far as replacing the hose from the elbow to the master as well, as I figured all new would be best.
Stock
It's a beast of a clutch if your tuner is worth a **** and your driving habits aren't that of an F-boy
Make sure you're planning to replace the master clutch cylinder right along with the clutch pipe and slave.
Good luck dude
Good luck dude
PyroMechanic
Aug 1, 2016 10:41 PM
genosis8703
Jul 14, 2016 09:55 PM
