replacing clutch disk
so while my cars apart and the clutch is sitting there I was thinking, why not put in a new flywheel and clutch disk? mine has seen some abuse but still has a decent amount of material left, but new will last longer. question is, do u resurface the pressure plate or just leave it?
NEVER resurface the LNF/LSJ flywheel. You WILL be taking it back apart in a few months. Always get a new Flywheel along with Flywheel bolts.....
Get the GMPP LSJ clutch unless you're big turbo then get something better..
But avoid the KYS3, it's a trans killer and the engagement sucks.
What clutch are you running tom? You will be making more power so it's probably not a bad idea. Unless you are building/installing a better trans in the next couple of years. How many mile are on it?
I'm running southbend stage 4+ at the moment and will me making a lot of power. I don't wanna spend 700 usd on a new clutch if I don't have to. I love the south bend. It's really not that old but I like new things with new motor lol. Just wanna know if changing The disk alone will work for me or not
You can always replace it when you replace the trans from running the 7163....😬
The trans is replaced and I'm running the s257 not the zfr
Just keep your mouth shut. Im getting tired of seeing your non sense and filthy mouth. Your a punk and nothing more. The fact that im wasting my time posting this is beyond me but meh..... Its people like you that make me not want to post here anymore. You should be delt with accordingly.
Post something useful for once and keep your swearing and bs commentary off the forum
So I looked at the pressure plate surface and it is very little wear. Almost new. So I'm gonna just leave it and probably get a new disk and flywheel
Talked to southbend , the recommend everything he was the user pressure plate and friction plate will have issues wearing properly when friction plate is new. So I'll just keep my clutch how it is, if I remember what side goes where, or I'll just get a New clutch period
Tom, I'd just get new stuff. resurfacing a pressure plate is a bad idea. You have it apart...dont do what I did and not spend the money only to have to take it out and do it 6 months later. trust me on this
did you even read the post? He said pressure plate. god you're an idiot
