S20G vs GT2871R
Old Jul 23, 2009 | 04:34 PM
BEASTmode632's Avatar
S20G vs GT2871R
whats the difference between these 2 turbo upgrades for the lnf? what are their ups and downs?
Old Jul 23, 2009 | 04:37 PM
reign1's Avatar
their both limited to 400HP
Old Jul 23, 2009 | 04:51 PM
well then they seem pretty pointless to me cause u can make over 350hp on the stock turbo
Old Jul 23, 2009 | 06:01 PM
Sw4y1313's Avatar
Because of fuel yes, but airflow, the S20G can flow well over 400whp worth of air.
Old Jul 23, 2009 | 06:12 PM
pookie025's Avatar
is dejons upgrade the best bang the 5457 upgrade. and the 54 is that the trim. how big is that turbo
Old Jul 23, 2009 | 06:29 PM
ive never looked a dejons. i dont know much about turbo upgrades so im just tryin to soak up some knowledge about the different turbo options for my car
Old Jul 23, 2009 | 06:31 PM
1BADSS/SC's Avatar
LOLZ
such a smart ass lol
Old Jul 24, 2009 | 09:50 AM
oldskool's Avatar
S20g will ultimately flow more air and make more peak horsepower. the gt2871 will spool up faster (its a ball bearing unit), and make a broad flat curve, but will be limited on peak hp. if you consider fueling and boost handicaps (good fueling to ~6500rpm and a 22.5psi boost cap), the 2871 will likely provide more area under the curve.
Old Jul 24, 2009 | 10:33 AM
reign1's Avatar
Originally Posted by 1BADSS/SC
LOLZ
hehehehe
Old Jul 24, 2009 | 10:40 AM
Mazdaboi318's Avatar
ive tried to find out different turbo options on our car. which is worth anything. no help.
Old Jul 24, 2009 | 11:02 AM
ecotecturbo's Avatar
Gt28 is too small for this car imo. The gt30 is what i would go with.
Fuel is not an issue, Just wait and see!
Last edited by ecotecturbo; Jul 24, 2009 at 11:02 AM. Reason: Automerged Doublepost
Old Jul 24, 2009 | 11:39 AM
i looked at the gt 30 too. will that not take longer to spool considering its a bigger turbo?
Old Jul 24, 2009 | 11:42 AM
The gt30 with spool just fine. The s20g is a very good turbo as well and cots less than the gt30.
Old Jul 24, 2009 | 11:44 AM
GT3071R seems to be winning. i just want one that will bolt up
Old Jul 24, 2009 | 11:48 AM
Talk to hahnracecraft they will set you up.
Old Jul 24, 2009 | 11:53 AM
Terminator2's Avatar
Fuel is definately an issue we dont have enough injection time at above 6500 to support a bigger turbo.
Old Jul 24, 2009 | 12:10 PM
Fuel will not be an issue real soon just wait and see.
Old Jul 24, 2009 | 12:31 PM
hahn is to much money.
Old Jul 24, 2009 | 12:44 PM
oldskool's Avatar
If there was proper fueling , boost and rev capability, the gt2871 would inch up on the 400whp mark...
Old Jul 24, 2009 | 02:42 PM
yeah hahn is a ****** rip off they are so expensive. yeah im looking for a turbo that will bolt right up too
Old Jul 25, 2009 | 02:05 AM
pookie025's Avatar
i think dejon is the place to go but i dont understand their sizes they have a 5457,5657,5857,and 6057 what do those numbers mean is the first two numbers out ouf the four the trim. ( what is trim by the way)
Old Jul 25, 2009 | 03:21 PM
peachpuff's Avatar
Trim is simply a formula of the inducer/exducer of the compressor or turbine wheel, its useless basically. All you need to know is the size of the inducer in millimeters. Im not sure if dejon is naming them by the size of the compressor wheel, but the first two numbers could be 54mm, 56mm, 58mm and 60mm inducers. The second 2 numbers might mean the size of the turbine wheel and the B means ball bearing.
The bigger the inducer the more hp its capable of making... and more lag.
Old Jul 25, 2009 | 10:30 PM
interesting
Old Jul 27, 2009 | 10:26 AM
davidcroft's Avatar
WTF is that supposed to mean?
Old Jul 27, 2009 | 10:29 AM
umrdyldo's Avatar
There are people working on fueling issues and hopefully we won't have that problem anymore.
