service esc
Old Apr 7, 2009 | 04:11 AM
Turbo08's Avatar
service esc
i was driving down the freeway a hot girl passed me in a wrx so i down shifted to 2 and nls to 3rd and then on the display it said service esc... i dont no what to do i dont want to take it in to the dealership and they i drive my car to hard and say your warranty is void.
Old Apr 7, 2009 | 04:31 AM
utsadude's Avatar
Hmm, did you turn it off and see if it's still showing when you start her back up?
Old Apr 7, 2009 | 08:51 AM
redninja6r's Avatar
What does a NLS have to do with ESC. Take it in, they won't void your warranty.
Old Apr 7, 2009 | 11:11 AM
turbaltss's Avatar
how fast were you going when you dropped it int 2nd? If you were going over 50 mph being on freeway you likely were. That's nasty hard on the drive train I would expect a cel of some sort doin that.
I know you posted it said service esc could it have possibly said esc active? if it was active it was just a notification that the Electronic Stability Control had kicked in and yes even in competitive mode the esc is still on (looser perameters for more aggressive driving). To totally turn the esc off depress and hold the traction button for 5 secs. the dic will read "esc off"
Old Apr 7, 2009 | 11:31 AM
Turbo'dSS's Avatar
idk what it is either? ive gotten it a few times on mine. i just ignore it. hasnt hurt anything yet. lol!
Old Apr 7, 2009 | 11:45 AM
Buddhaphish's Avatar
ditto
Old Apr 7, 2009 | 11:48 AM
SlyderRE's Avatar
maybe it detects wheel spin from DSing and thats why it came on
Old Apr 7, 2009 | 12:28 PM
Zander916's Avatar
I have the same issue. It's completely random. It resets when the car is restarted as well.
I called onstar while it was happening and they didn't tell me anything the DIC didn't tell me already.
I'm just waiting until I happen to be free when it happens (not on my way to work) and take it to them while it's active. It was in there once and they made an attempt to correct it although it wasn't actively doing it for them.
I have also noticed on mine that once it happens the cruise control also stops working.
If I get an answer before you do I'll post back up. Otherwise, PLEASE post up what you find.
Oh btw... I'm tuned. They scanned the car for codes (my airbags were also shutting off) and they never found out about the tune. I wouldn't worry about it.
Old Apr 7, 2009 | 01:51 PM
reign1's Avatar
maybe your car said ffffffffff uuuuuuuuuuuu i dont care how hit the chick is, its a wrx.....
lol jk man
Old Apr 7, 2009 | 04:41 PM
turbobalt's Avatar
t.c
I've had this happen to my 09 ss.but in my t/c our air/air fuel gauge says no service also.I just turned it off and it went away.
Old Apr 7, 2009 | 06:21 PM
celicacavy's Avatar
it coulld have been a ABS sensor messed up, i know that GM made the ABS sensor a part of the wheel bearing on some models but not sure if they did on these, (havent looked that closely) but if it did you could have stressed the wheel bearing to the point that the sensor could not read and then it disables sability control till it can read again
Old Apr 7, 2009 | 06:58 PM
jb09ss's Avatar
I had the "service esc" pop-up on the DIC a few times, but only on snowy or icy roads. Mine did it when both the mechanical lsd and the brake activated lsd failed to prevent a "one wheel peel" and the car detected a difference in front wheel speed that is too high and for too long. That could lead to differential damage and this is why that message will appear. If you did that on asphalt, I guess that your car don't have the lsd and you were one wheel peeling like a champ trying to impress that hot chick in the wrx.
Meadowvalien
Aug 17, 2017 06:32 PM
patooyee
Oct 15, 2015 05:11 PM
bigdogstokes16
Oct 8, 2015 10:28 PM
importkiller
Sep 30, 2015 07:18 PM
grampss
Sep 27, 2015 08:51 PM
