Should be quite a bit better flow and still retaining the stock pcv system...
Old Jan 31, 2013 | 01:41 AM
FasterIsBetter's Avatar
3.6 DI Throttle Body, Ported Stock Intake Mani with gasket matched runners. Heres a comparison vs. stock. Name:  2013-01-31_01-07-01_226_zps111b792c.jpg
Size:  193.3 KB Name:  2013-01-31_01-07-38_883_zps9e31903c.jpg
Size:  129.0 KB Name:  2013-01-31_01-08-03_761_zpsf52b46f9.jpg
Size:  152.4 KB I'm guessing it may gain around 20chp across the powerband maybe not peak. Throttle response should be great. The porting on the runners isn't finalized. Still needs smoothed out with some high grit sand paper but all casting imperfections were removed. Its already much smoother than the cast. Had the opening at the throttle body machined half an inch larger.
Old Jan 31, 2013 | 09:29 AM
DirtyBalt09's Avatar
How will tuning go with the new throttle body?
Old Jan 31, 2013 | 09:38 AM
ItalianJoe1's Avatar
In for results, will probably drive kinda funny with that bigger TB, but it should flow better at WOT.
Old Jan 31, 2013 | 11:54 AM
ford's Avatar
sub'd for home.
Old Jan 31, 2013 | 12:00 PM
umrdyldo's Avatar
Good idea, but I bet this really screws with tuning. Good luck.
Old Jan 31, 2013 | 01:07 PM
Just adjustment of fuel trims and the idle air control values. Same as tuning an lsj for an ls4 tb just slightly more drastic in the changes.
Old Jan 31, 2013 | 02:09 PM
umrdyldo's Avatar
Have you done this? Because some of the peeps around here seem to disagree on opening up the intake manifold and throttle body.
Old Jan 31, 2013 | 05:35 PM
If the car doesn't like it, I have the stock tb and intake mani sitting ready to be put back on it. It still may end up going back on it and sold with the car. But it was just some things I had sitting around that I bought in the past. I forget what shop did it but gasket matching the stock intake mani and porting the tb made the cars responsiveness and driveability better. I have them on facebook. Seems though the biggest issue comes from people doing their own port work on the head due to the way the flow should be across the valves for di.
Old Jan 31, 2013 | 07:50 PM
umrdyldo's Avatar
I thought I remember ZZP trying a bigger or ported throttle body with lackluster results.
I really hope this works. Would help the big turbo cars.
DarrenGC
Dec 24, 2021 01:55 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
