smoking issue
Old Jul 23, 2012 | 01:56 PM
paintballerr78's Avatar
smoking issue
After driving my car one day I shut it off filled it with gas turned it back on started smoking terribly so I shut it off then back on after couple minutes barely any smoke. I remove my turbo there was oil in the xompresor housing now I also have my crank vent and pcv valve floating around not hooked up. Some people say turbo seals some say to much crank pressure. I'm going to do a compression test on it today see of its got low compression the cat only smokes at idle not while driving. Also the Turbo has no shaft play at all
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
