snow perormance NITRO BOOSTER?
http://www.snowperformance.net/product.php?pk=5
it says it will add 30-50 whp with adding it to their 50/50 boost juice meth mixture. is this true. its hard to believe...
lol i find that hard to believe as well. I have not seen any dynos on that. Plus you have to add 2 bottles to each gallon of 50/50 mix and they're $30 a piece. So $60 and it only goes one gallon? Man i dunno about that
I tried that once in the mustang with my nitrous/meth setup. On the first pass it melted 4 plugs LOL. I'm not saying it doesn't work but my car was tuned to the edge and that stuff put it over. For the 1/8th mile that I was in it the car did pick up .8mph. Nothing to write home about but the stuff did make more power.
you can buy a 5 gallon bucket of nitromethane for $210 from buyracegas.com. thats pure nitro for $42 a gallon. i think $20 of that price is for hazmat shipping cost
It is legit, HOWEVER if your not interested in overboosting, melting the ring lands, cracking sleeves or otherwise destroying things you have to take the head off to fix, don't use it. There are setups made for this, and I'm sure their CSR department will affirm that you should not use it on a factory engine.
just wondering where you found this information? im also wondering how many ounces their bottle is?
I run 2 bottles per 5 gallon bucket of water/meth and saw a 7whp gain. I would absolutely not run it in the concentrations snow suggests which is 1 bottle to every half gallon to get there hp claims. This was also on a almost 700rwhp car so the gains are about 1%. I take 1 year to go thru 5 gallons so its not an issue with me but def not worth it if your a daily user.
I have some of this stuff but ive yet to test with it, there is a difference between it and just regular nitromethane, the snow stuff has an emulsifier in it because normally water and nitro dont blend, if you were mixing non snow stuff with regular 50/50 water meth that could be why you had boom.
The proper mixture is .125 or 7/8ths which means 1 part snow stuff and then 7 parts of equal volume, doing it in this fashion should not affect AFR, not mixing it proper concentration could have undesirable effects
