Some LNF #'s w/ upgrades
Via the solstice forums:
stock LNF 239whp Hahn BSR tuner only 258whp BSR tuner w/ upgraded intercooler 268whp. All on stock intake and stock exhaust. http://www.solsticeforum.com/forum/s...ad.php?t=38345 Dyno http://i91.photobucket.com/albums/k2...ntercooler.jpg |
ok the fact they had smoothing at 5 and did a run w/ shifts is just retarded.
NTM does anybody even know what ECU the 'balt will have? if it's the same then the "bsr tuner" may be compatible (barring dif OSs), if it's dif then this whole thread is (likely) moot. |
Either way, with the Cobey being turbo, I believe that there will be some pretty decent potential involved, ESPECIALLY if GM made adjustments to the drivetrain to correct some issues that were had such as the tapered axles.
I think this is good news, the turbo Cobalt part of it that is. lol |
Originally Posted by bc3tech
(Post 1617389)
NTM does anybody even know what ECU the 'balt will have? if it's the same then the "bsr tuner" may be compatible (barring dif OSs), if it's dif then this whole thread is (likely) moot. It's the same ECU as the Solstice GXP; https://www.cobaltss.net/forums/08-10-ss-turbocharged-general-discussion-152/2-0l-lnf-ss-turbocharged-frequently-asked-questions-%5Bread-me%5D-82531/ |
those solstice guy's BEAT there cars... here's a SKY RL with 275 RWHP 305 RWTQ STOCK jus retuned to 23 psi...
http://www.*******.com/forums/sky-di...nds-boost.html ^put in redlineforums post #16 |
Originally Posted by thedubsack85
(Post 1618065)
Originally Posted by Spectral
(Post 1618598)
lmao that is not going to be good. atleast what im getting from all the info i have read that if you turn the boost up your going to screw your turbo in the long run because it is too small. if you want to push higher PSI you need to swap turbos.
those numbers are okjay...we got some ss/sc pushing 280-290whp
Originally Posted by Jimmys2007CobaltSS/C
(Post 1618636)
Originally Posted by Area47
(Post 1618656)
ding ding!
Originally Posted by M-Dub
(Post 1618749)
yes that'd be you
(Post 1618636)
Go back and look at the ss/sc # from 2005, early 2006 we weren't in the 280-290 range. |
Originally Posted by 1gmfanatik
(Post 1617410)
I think this is good news, the turbo Cobalt part of it that is. lol I believe that the spring rates were changed probably to reduce wheel hop..axles may be the same |
Originally Posted by BLKblurr06
(Post 1618778)
Originally Posted by SilverSS/SC
(Post 1618804)
the axles for 2008 are new designs . They focused on dampening the harmonics that traveled thru the axles caused by wheel hop . The harmonics is what caused them to crack in the old design .
(Post 1618636)
thats why you swap to a twinscrew..
Originally Posted by 3ds138
(Post 1619116)
(Post 1618636)
does this thing come with a front mount. I ouldnt tell in the picture all that well. If it does that seals the deal, tommorow at work ill talk to the sales manager.
Originally Posted by REIGN SS
(Post 1618839)
Im going to quote from another thread:
Originally Posted by DebadgedBALT77
(Post 1619137)
(Post 1619145)
yeah ive NEVER seen the axel's crack. i HAVE granaded a driver side axel at the inner CV (the one that slide's into the hub) i hope they redisgned everything. espically the trans housing.. cause some poeple were cracking tranny housing's BEFORE snapping an axel. and ending up with a voided warrenty for racing.
thank god my eyes werent decieving me, A nice frount mount is all really wanted. I wonder what month exxactly these will be hitting the lots. Since I do all the PDI's at work, as soon as we get some Ill get a video and post that up. Better get my finances in order. Tradeing in my 05 2.2L for this would sure be nice.
^^ Think April'ish . 2nd quarter is april/may/june . They should have a more specific date by the autoshow season .
OMG .... a sporty car thats being released in the dead of winter ( solstice , 05 vette ect ) |
Originally Posted by Brandon97Z
(Post 1619103)
Show me an LSJ running almost 260whp from a tune alone. The guys running those numbers with the LSJ's are running delicate tunes w/ full bolt-ons and meth injection. Not to mention the Cobalt with the LNF will see higher numbers due to less drivetrain loss.
hell i put down over 260 with a 2.8, stock tune, and an intake. how is the drivetrain loss in the lnf cars less than the lsj? |
