Someone Help Me
Im throwing a Cel my mods are Crazy steve intercooler, ZZP catless Dp, Forge BPV, muffler delete. I dont remember what the code was but the description of it was lean to rich in bank 1 and 2 and it only comes on when i go WOT. Im still learning about the LNF but i have a feeling its because of the Ic and dp...I am getting tuned soon.
The code is probably either P013A (HO2S Slow Response-Rich to Lean Bank 1 Sensor 2), P013E (HO2S Delayed Response-Rich to Lean Bank 1 Sensor 2) or even both. Either case, it is due to your catless dp not being turned for.
Idk, I did it with a scanner from auto zone and I mostly concentrated on lean to rich and clearing the code.
The codes wont cause any run issues for the time being but just keep an eye on the codes to make sure something else unrelated to the bank 1 sensor 2 doesn't pop up.
Yea I figured bank 1 and 2 meant the o2 sensors and ok Ill keep a eye on it. Its popped up maybe 5 times and 2 of the 5 times it said the same thing. the other 3 times ive cleared it by unplugging the battery I just thought it was weird since it only comes on once and while and if it does its when I go WOT.
