Someone Help Me
Old Aug 22, 2012 | 06:03 PM
BlackARCA06's Avatar
Exclamation Someone Help Me
Im throwing a Cel my mods are Crazy steve intercooler, ZZP catless Dp, Forge BPV, muffler delete. I dont remember what the code was but the description of it was lean to rich in bank 1 and 2 and it only comes on when i go WOT. Im still learning about the LNF but i have a feeling its because of the Ic and dp...I am getting tuned soon.
Old Aug 22, 2012 | 06:21 PM
09CobaltSS1's Avatar
The code is probably either P013A (HO2S Slow Response-Rich to Lean Bank 1 Sensor 2), P013E (HO2S Delayed Response-Rich to Lean Bank 1 Sensor 2) or even both. Either case, it is due to your catless dp not being turned for.
Old Aug 22, 2012 | 06:24 PM
SSlobalt's Avatar
The bank 2 error is impossible. You only have one bank of cylinders.
Old Aug 22, 2012 | 06:50 PM
Yea those were the codes! will this cause any problemes in the mean time? I wont beable to get tuned for a few weeks.
Idk, I did it with a scanner from auto zone and I mostly concentrated on lean to rich and clearing the code.
Old Aug 22, 2012 | 06:54 PM
SSlobalt's Avatar
The slow-response DTC doesn't affect how the vehicle runs. It's just trying to tell you that you don't have enough air going past the O2 sensor.
Old Aug 22, 2012 | 07:02 PM
Yeah what you were quickly reading as "bank 2" was actually just sensor 2. Like SSlobalt said, there is no bank 2 in a inline 4cylinder.
The codes wont cause any run issues for the time being but just keep an eye on the codes to make sure something else unrelated to the bank 1 sensor 2 doesn't pop up.
^^ This..
Old Aug 22, 2012 | 07:48 PM
Yea I figured bank 1 and 2 meant the o2 sensors and ok Ill keep a eye on it. Its popped up maybe 5 times and 2 of the 5 times it said the same thing. the other 3 times ive cleared it by unplugging the battery I just thought it was weird since it only comes on once and while and if it does its when I go WOT.
Old Aug 22, 2012 | 07:49 PM
Ok that makes me feel better.
Old Aug 22, 2012 | 08:43 PM
SSlobalt's Avatar
I still haven't tuned mine out yet. I get is when I let off of a WOT hit, usually in 2nd gear.
Old Aug 22, 2012 | 08:49 PM
^^ Lazy bum..
Old Aug 22, 2012 | 08:50 PM
Yea that's exactly when mines comes on. Lol I'll just let it go now till I'm tuned it sucks clearing it all the time.
