Southbend Clutch Vs. ZZP Vs. KY
Old 01-08-2012, 12:40 PM
sponge14's Avatar
Through all the research I have done, I am deciding between the 3 brands above. The first question I have is what is the difference between a clutch that I get directly from Southbend/DxD and the ZZP offering? I have read Southbend makes them for ZZP, and they are quite a bit cheaper than the ZZP, so what is the difference?
Southbend recommended their clutch that holds up to about 400ft lbs. Right now I am just Trifecta tuned with basic bolt ons, but I do want more power in the future, probably the ZZP EFR. I assume I would need more than holding to 400ft lbs for that. Should I buy for the power I have, or the power I want?
Finally, how does the KY compare to the above 2? I know people always like to argue that they are just as good and cheaper, but if you take into account the Southbend, they lost their money advantage there.
Old 01-08-2012, 12:51 PM
Dart_SI's Avatar
zzp stage 4 clutch IS a southbend clutch. and IMO its the best clutch out there. my friends ss/tc feels just like my stock clutch.
Old 01-08-2012, 03:43 PM
SSlobalt's Avatar
With or without the adjustable clutch rod?
Old 01-08-2012, 05:36 PM
sponge14's Avatar
I'm curious as to which Southbend it would be, and do they modify it or is it just re-branded?
Old 01-08-2012, 07:36 PM
vahdyx's Avatar
I second this question
Old 01-08-2012, 07:42 PM
whyyoumadson?'s Avatar
i hate southbends clutches thats just me. spec stage 3 + held up with no issues ijust dont recommend it with the stock flywheel.
Old 01-08-2012, 07:59 PM
TurboTechRacing's Avatar
X2 this is the setup I have on my SS/SC.
Old 01-08-2012, 08:27 PM
Dart_SI's Avatar
without the clutch rod.
Old 01-08-2012, 10:51 PM
SSBalt's Avatar
KY clutch holding up just fine so far 2k miles. Being a 6 puck, engagement takes a while to get used to. Slipping this clutch was an exercise in madness. I've always been a 'slipper', and It was hard for me to change ways after 22 years. Now that I'm used to it, I kinda prefer it. Just let the damn thing out and the car always goes, no gas needed.
Old 01-09-2012, 12:34 PM
sponge14's Avatar
I understand there are many opinions on clutches here, but I think I can safely narrow it down to the 3 options I listed. I think with any more options I would drive myself nuts!
Does anyone know the difference between a Southbend and ZZP?
Old 01-09-2012, 12:39 PM
You have 2 choices listed, as those, as already stated are the same thing... (per post #2)
So that is why we, and 1 other member, made it 3 kits, and stated the spec stage 3+
Old 01-09-2012, 12:41 PM
sponge14's Avatar
Touche.... Do you know, are they exactly the same then?
Old 01-09-2012, 12:42 PM
Ask Dart SI... I have read many times on the forums they are, but we personally dont know.
Old 01-09-2012, 12:44 PM
sponge14's Avatar
Okay, thanks alot for the help... I have read that they were made by SB for ZZP, but I didn't know if ZZP does anything to it after they get them....
Old 01-09-2012, 12:48 PM
robd53's Avatar
Subscribed. I don't know what clutch is in my car now, but if I hit 2nd hard on dry pavement she slips so my research has begun.
I had a Spec stage III in my 2.4 / 5 speed turbo grand am. I loved it... was kinda like an on off switch though.
Old 01-09-2012, 12:56 PM
Chevycobaltss3's Avatar
I'll say this, I worked on a customers car that came in with a southbend clutch. The reason he came to me was no clutch. I took the clutch out and the friction disc was froze to the actual pressure plate. So I hammered that bitch off. Lol. The ky clutch has been tested mainly on my car. I thingmk I've done 6 setups and the next is a twin disc setup. Specs are good and is recommend them more then I would clutchmasters. Spec uses known pressure plates as does clutchmasters but spec uses better materials with they're friction disc. It's all about preferences really. Ky clutch new revised pressure plate !nd friction disc hold up on my 30lbs, ad someone has dynoed 447ft lbs already and let me know. I forgot his name here and I hope he comes in. But in all honesty they are good for a certain criteria and all make there clutches in these.criterias ... So it all depends on pocket money and your honest to god wants.
Spec is by far out of all the known name brands best for the balt I feel. But power wise make sure to order the correct one.
Get with ttr for the specs.
Old 01-09-2012, 01:02 PM
RoadconeTuning's Avatar
I've personally never heard of south bend clutches prior to reading about zzp being made by them. I was going back and forth between the ZZP Stage 4 and Exedy Hyper Single and I just recieved my Exedy. I've read nothing good about the KY in my research and the Spec is only okay if you get a plus clutch and then you have to have the flywheel dowel holes enlarged too. I figured for under 1100 i can get a light flywheel and clutch that holds whatever i throw at it.
Old 01-09-2012, 01:09 PM
So what did u hear about ky clutch lol. People ordering the incorrect clutch for they're power? Or the tb.... A lot of the tvs were due to improper installments. Some weren't but this is a gm error an the mfg error.... Please explain.
Old 01-09-2012, 01:10 PM
The exedy hypersingle isn't rated high Tq at all.
Old 01-09-2012, 01:19 PM
Stamina's Avatar
If anybody wants to go the Spec 3+ route, I've got one, fresh, still in the package.
https://www.cobaltss.net/forums/part...ackage-266285/
Old 01-09-2012, 01:21 PM
BooSSted's Avatar
These clutch discussions are getting out of hand
Everytime I make up my mind, I read more reviews of other **** and it gets me thinking again.
I had decided on the KY but I am SUPER nervous that it's going to be too harsh and I'm going to hate it......
UGH!
Old 01-09-2012, 01:23 PM
Lol. Honestly any ceramic engagment is grab to a point.
Old 01-09-2012, 01:28 PM
Dart_SI's Avatar
Iirc zzp tested the clutches from southbend till they got it "right' and got southbend to produce the clutches for them at their specs. Imo they did a great job with that clutch. You guys really need to drive a balt with a zzp s4 and feel for yourself how stocklike it feels.
Old 01-09-2012, 01:30 PM
68Vette's Avatar
Going by what I have read ACT seems to have the best clutch for our cars - I cant speak from personal experience as I'm still on the factory clutch.
I have and it is not all like stock.
Quick Reply: Southbend Clutch Vs. ZZP Vs. KY
