Spark blowout during NLS
Bringing this back from the dead. I believe I have figured out the root cause of NLS misfires. It has to be compression related. I have recently installed brand new LDK with same setup as previous engine. Have not been able to force ANY NLS misfires no matter how late I shift in rpm, or how fast I shift. I've also successfully NLS with outside temps ranging from 60-85 degrees. Also considering the fact that NLS misfires were getting more frequent with the last engine before it popped while compression readings were between 120-130 across the board. Lmk if you guys think I'm overlooking something.
The Rookie24
Sep 20, 2015 04:33 PM
