Spark Plugs
Spark Plugs
Anyone use anything other than stock/OEM plugs? Any need to gap them (or the stockers) differently for increase boost applications?
I've always been a fan of the NGK's for my Camaro. Just have to change 'em out more often. Don't know what plug would be a direct replacement for our cars though.
I notice my car idles a little rough from time to time. It's pretty rare, but noticeable when it happens. Thinking the plugs might be the cause. Ideas? Suggestions welcome.
I pulled mine over the weekend to check the gaps, as they were off on my old ss/sc. The 4 plugs had about a .005 range from biggest to smallest - at least on this car they are all .035 on the dot.
They are made by NGK. To the OP your rough idle could be a result of oil leaking into your cam sensor electrical connector. Mine was doing the same thing periodically, but ever since I cleaned all the oil out of the connector I have no rough idle issues anymore.
Hey ive got a cobalt ss/sc with the stage three gm and the k&n typhoon...but i can tell my plugs are gettin bad at high rpm-heat ranges...i havent gapped them or changed them with the stage upgrade...i know i have to get diff ones but what are the best ones to get and at wat gap should i put them. runnin about 17 lbs 7K rev?? PLZ SUGGESTIONS!!!
agentirons
Oct 16, 2015 02:11 AM
