ss/tc owners with a second pcm!!!!!!!
Im looking into picking up a used pcm for my ss/tc because i want to get mine tuned but after all of the info i read about gm being able to find tunes, its making want a second pcm.
Whats involved to get it to work, is it just plug and play or does it have to be calibrated by the dealer????
Thanks in advance
Thanks in advance
hit up GTPrix. ask to buy one. hell tell u where to pay pal him. put ur VIN # in the comments box. wait a week or 2. comes to ur house.
unplug stock ecu. throw on the new one. crank it once. turn it off. crank it one more time. (FYI ur oil life resets)
then go tune it. bam. done. ready to go
mines on the way
do you have to unplug your battery b4 you swap? im gonna probobly get a quick disconnect for my negative battery terminal. i find myself ******* with my battery alot lately
yeah just remove the plugs. dont b afraid tho. remember to crank it once. THEN TURN THE KEY BACK! or it will keep cranking. then turn the key the second time. and it should fire right up. let it run for like 5 mins or so
im pretty sure they can tell if you been tuned even with a second ecu, they will just scan your body control module. least so i have heard not 100% but i have heard this alot.
i would do it the other way around if you could otherwise it might throw a red flag if they notice that the ecu isnt the factory one bart. they might start asking why its been replaced
Last edited by OneCOLDBIZL272; Jun 14, 2009 at 03:14 AM. Reason: Automerged Doublepost
