ss/tc shifters???
I haven't seen too much on shifters for the tc as the transmission is the same as the sc but some threads were saying that the reverse lock out is goofy on the tc. Anyone have a short throw shifter on their tc with no problems and full functioning reverse lock out???
Originally Posted by hiltu
(Post 2910638)
mine works perfectly fine
mine works
order one for a 07 or 06 cobalt ss i think b&m and hurst fit on a 08+
(Post 2910638)
Kevin TWM Performance |
Sounds good, look forward to hearing back from you.
Anyone have an image of what the shifter looks like stock and aftermarket with the boot off?
:cssNET: |
Both B&M and Hurst will work fine on your car. If you are looking for a B&M unit send me a PM... we have a lot in stock so I can get you a sweet deal on one :)
-Karo |
Karo, my only beef on this whole subject is the reverse lock out not working. Once I get proof that it will still 100% work, I would love to look into one...
I see no reason why it should not work....
Want me to send you a shifter for you to try it out? If it works, pay for it, if it does not send it back? -Karo |
U said u only have the B&M shifter in??? i like the hurst better, so Yes, if u have the Hurst shifter in, I would love to try it out
(Post 2913671)
-Karo |
PM sent
How much for the B&M and how much for the Hurst for the 08 SS/TC, I thought the ss/tc came with short throw shifters?
Are either of these models true short throw shifters, or are they just a shorter shaft and the illusion of a shorter throw?
I want a shifter that actually moves the position of the back and forth linkage farther down which in turn will give you a truly shorter throw. |
Originally Posted by MapOfTaziFoSho
(Post 2915454)
I want a shifter that actually moves the position of the back and forth linkage farther down which in turn will give you a truly shorter throw. Both B&M and Hurst units have lowered the pivot point which truly gives it a shorter throw. They did not take a stock unit, remake it out of metal and just chop the shaft down... when they built the Cavalier shifter off our race car it was interesting to see how they measured everything and how much the throw was less vs stock... -Karo |
Originally Posted by Karo
(Post 2915988)
-Karo |
(Post 2916049)
What % does it reduce throw?
-Karo |
The throw reduction is about 30% with Hurst & 33% with B&M. Thats what Aaron (TTR.com) posted
Hey guys,
We just got confirmation from a customer that the TWM short shifter does in fact fit the SS/TC :) Check out the reviews in this thread: https://www.cobaltss.net/forums/show...82#post2925882 The TWM Short Shifter reduces shift knob height by 1" inch and throw by 33%, more than the other short shifters currently available. They're still at an introductory price for the rest of the month, don't miss out! TWM Cobalt SS/SC and SS/TC Short Shifter Sale Thanks, Kevin TWM |
Originally Posted by TWM Performance
(Post 2926457)
Hey guys,
I just installed a B&M on an 05 ION REDLINE and the shifts are not as short as on my stock T/C shifter.
And I also fixed my reverse lockout, the left and right shifter cable needed to be adjusted, very simple. |
Mine works great
(Post 2926457)
Hey guys,
