steering wheel skaking
Old Jun 2, 2010 | 06:30 PM
pookie025's Avatar
Question steering wheel skaking
idk why but on the high way the steering wheel shakes a 50+ mph any thoughts. im not pressing the brakes at all!!
Old Jun 2, 2010 | 06:34 PM
blake05SS's Avatar
get an alignment
Old Jun 2, 2010 | 06:35 PM
ecot3c inside's Avatar
any one of your wheels out of balance?, Mine only does it sometimes RARELY so I just never looked into it.
Old Jun 2, 2010 | 06:36 PM
06G5GT's Avatar
Your wheels are out of balance or you have a bent wheel.
Wheel alignment will not cause a shake or vibration.
Old Jun 2, 2010 | 06:39 PM
Permafried-'s Avatar
Is it speed -> speed then goes away, or does it get worse as your speed increases? If the latter:
1) Out of balance or bent wheel (weights are known to randomly fall off)
2) My stock front rotors were warped on my TC and it got worse with speed (and even worse under braking)
Old Jun 2, 2010 | 06:59 PM
tom.g's Avatar
Agreed!
If the feeling gets worse when your braking it's probably warped rotors. If the feeling doesn't change it means your wheel(s) is out of balance.
Old Jun 2, 2010 | 07:14 PM
pookie025's Avatar
well i got brand new r1 concept rotors all around. and it happens when i increase my speed then it gradually goes away. when i brake it doesn't shake at all.
mrgrinch's Avatar
Anyone have a problem when slowing down from like 50+ mph and the wheel shaking like hell?? mine does it everytime i slow down from around 50, what could be the cause, have no issues with this other than when i'm braking from that speed or higher.
Old Jun 2, 2010 | 07:41 PM
09CobaltSS1's Avatar
uh oh.. Travis fucked your **** up!!
Old Jun 2, 2010 | 07:42 PM
Out of curiosity, does it do it everywhere, or only on the same stretch of road? Have ou seen huge fluctuations in ambient temperature lately (ie. stupid hot during the day, cool at night, next day totally different, repeat)?
Old Jun 2, 2010 | 08:06 PM
JTurner.CTN's Avatar
Have you ever had your tires rotated or balanced? You usually notice a car is out of balance at highway speeds that's probably your problem.
And to the guy who's steering wheel shakes under braking your pads/rotors are probably messed up somewhere,
Old Jun 2, 2010 | 08:17 PM
tomj77's Avatar
i can tell u right know what it probably is as its done it to me in many cars, u washed ur car, and didnt get all the mud out of one of the rims throwing the car off balence, shakes like crazy past 50ish mph, before u go thinking its something crazy like everyone is saying, clean ur rims good and see if that helps
Old Jun 2, 2010 | 08:34 PM
Still means it's off balance.
Old Jun 2, 2010 | 09:11 PM
black67's Avatar
If you just did a brake job, have you checked the torque of the lug nuts after about 25 miles? They will loosen up sometimes after a short run.
Double check to make sure your lug nuts are properly torqued and look for the wheel weights to make sure that you have not lost any them.
Old Jun 2, 2010 | 10:54 PM
pookie025's Avatar
i had my sway bar end links replaced under warranty and the tech said my lug nuts were way to tight... and he loosened the one where he replaced the end link. so three way too tight and one normal.
Old Jun 3, 2010 | 09:47 AM
efactor's Avatar
Old Jun 3, 2010 | 03:08 PM
SSlobalt's Avatar
warped front rotors.
Old Jun 3, 2010 | 05:00 PM
Terminator2's Avatar
Not warped per say. Rotors do not warp they build uneven deposits on them which causes that uneven feel a you apply the brakes. Basically the thickness of the rotors is different in some areas which causes the pulsation.
Old Jun 3, 2010 | 06:58 PM
SSlobalt's Avatar
Uneven front rotors.
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
