Stock Boost solenoid On s257, Pics, need help
Old Feb 6, 2016 | 11:14 AM
jcalvin1126's Avatar
Ok so I know where the lines go from the boost solenoid, However the 257 does not have a compressor port of which I can put the line for boost pressure.
Here is stock boost solenoid.
This is the 257
I had thought that the ports on the left were one of them, but upon further review those ports are not drilled through. Rather tehy look like mounting holes.
^larger hole
^Threaded hole on compressor side.
Smallest hole
Any advice as to what I should do with it? I want the stock boost solenoid for Km034 to tune to boost instead of a manual boost controller.
Old Feb 6, 2016 | 11:51 AM
blueLNFftw's Avatar
You have to drill and tap them.
Take the compressor housing off to do it.
You may want to just have a shop do this......
Old Feb 6, 2016 | 12:44 PM
The one with two holes is for a turbo speed sensor.
Old Feb 6, 2016 | 12:54 PM
tomj77's Avatar
the hole with the the smaller hole beside it is the compressor speed sensor hole, leave that one, drill and tap the other one. or just run a line from you cp to the solenoid, u don't actually have to go off the turbo, it will just be slightly more accurate.
Old Feb 6, 2016 | 01:02 PM
Hey thanks guys, Figured it out.
This hole is allready threaded for the boost source. Turns out since soo many different ways to do this. (i.e. No speed sensor/ manual boost controller which doesnt need the boost source) they drill to the end of the housing, allowing the option to drill a small hole through it and using the allready made threads threading in a fitting. So Im going to the parts store to get the correct fitting for the threads and drill bit today.
this is the fitting for the boost source
Old Feb 6, 2016 | 11:41 PM
tomj77's Avatar
I wonder if u could just put grease on the bit so u wouldn't have to take off compressor housing, that should keep any shavings from falling in. but idk, risky.
Old Feb 7, 2016 | 08:50 AM
Taking the housing off isn't hard at all. I did it all in like 30 minutes remove and install.
94gts
Apr 4, 2016 09:05 PM
Cobaltsky05
Feb 26, 2016 10:52 PM
derekseay
29
Feb 26, 2016 10:52 AM
Cobaltsky05
Feb 3, 2016 11:26 PM
Staged07SS
Sign Something
Feb 3, 2016 07:13 AM
