Synapse Motorsport Dyno Tune on our Cobalt
#126
got another one. Getting some shop time to install it on the 16th. Car is still driveable, but I can't go over 3k rpm above 1/3 throttle. I still can't believe the stock clutch held out so long. I think I got a little over zealous with the WOT box lol. **** is addicting.
#127
#128
Rent me! per hour
one of these days, i will be in your shoes with the clutch issue.
#129
Oh there will be plenty
yeah I"m switch over to the aem emth injection, has a nice bypass solonoid and is just boost activated. Hopefully install that the same weekend as the clutch, then it's retune and new dyno numbers time.
Last edited by 06blackg85ss; 08-01-2008 at 12:07 PM. Reason: Automerged Doublepost
#130
Even thought the SS/TC makes great numbers all it takes is a turbo kit for the LSJ and you are right in the same ball park for 2-4 thousand + the SS/SC will be paid for.
#131
without the better handling, better breaking etc but yeah. Not to mention it is always better to start with a turbo platform if you plan to have a turbo platform... So what would the 2-4k include? turbo, ic piping, injectors, flashing/tuning, exhaust manifold, exhaust, intake, plus all the gaskets and odds and ends you need? Sounds like a lot of work just to have an equivalent car and still not have the direct injection, better mpgs and reliability of an originally turbod platform... but to each his or her own
#132
^^^ why not just buy a base balt for like 7000 and turbo that then? this is the reason why people modiefy their cars. me personally would like to start out with the best platform. i.e. the ss/tc and work from there.
#134
Just stumbled upon this. Thats some nice torque but it's very clear the turbo is maxing out. I'm sure on the street it's nigth and day but at the track the differences will be less significant.
I can't wait for somone to turbo swap one and see the true potential of direct infection.
#136
I wanna go to track on 23-25 psi on stock turbo with bottle and see what i can do 1st next week if it doesnt rain, then ill switch to a 20g
#138
I know I am biased (see sig) but... yeah.. there are other differences between the turbo and SCed SS Cobalts.
Clutch for one is different... I believe the suspension/wheels are different.
and your suggesting taking your Supercharger off.. and replacing it with a turbo kit..? Lawlz
#139
Nice preliminary numbers and it'll be interesting to see what you can get out of it once there is better support for tuning the LNF in HP Tuners. Also interesting to see how much overhead there is in fueling.
What you're seeing is the characteristic torque curve of a smallish sized turbo for the application and a manual boost controller. It builds boost fast, spikes hard (i.e. the torque peak), but can't sustain the flow and starts dropping off as revs climb. While the turbo looks to be reasonably well matched for a stock engine it probably doesn't have a ton of headroom.
It does appear to be holding horsepower reasonably well on the top end so it will be interesting to see how much further it can be pushed and how the car responds to other modifications. It would also be interesting to tap the manifold and take some EGT and backpressure readings as well as some other logging such as intercooler inlet/outlet pressure and temp, take the exhaust temporarily off, open up the intake, etc. to see what, if any, those other parts are limiting power.
Testing, testing, testing. Ah, the fun of a relatively new powertrain installed in a new/different platform.
#140
#141
Yes it handles better and brakes better but you make the SS/SC sound like it has drum brakes and a leaf spring suspension lol. In braking tests the TC stopped in 115ft the SC in 120.15ft . Skid pad TC .89G's , SC .87G's TC slalom 69.3mph 67.5 mph . The TC is better , but the SC is still pretty damn good.
People have been "taking off their superchargers" before the TC was released , why the lawlz? Turbos are more efficient than root style SC's , so it's logical to do if you want to make higher HP numbers. A turbo swapped SS/SC is easier to tune right now , and in most cases, it's more cost effective for a SC owner to do VS trading for a new TC
I'm not a TC hater by any means, it's a step forward , and has even more potential . It just seems like some SS/TC owners think that the SS/SC is a washed up POS. IMHO it's still a great car .
*All performance info was from edmunds, the only reason is they most likely used the same track's , testing equipment and test drivers.
#142
Sometimes it a progression - and sometimes its a regression.
The SC is awesome. The TC is just an improvement.. Who knows what we'll see next.
Look at the EVO 8, 9 and 10. 8 was good, 9 was better.. 10 is a step back (in my book).
#143
That's the truth! The EVO 10 is a step in the wrong direction. I hope if the Cobalt brand continues that we see something even better!
#145
#146
#147
yea it was the driver... I seen a stock Evo X at the track run as fast as a 13.4 and as slow as a 13.9....I ran a 14.1 lol
from a roll the t/c has a chance
#148
With the turbo's torque peaking sooooo early you can see how a bit larger turbo will do wonders for this car!!!!
So who is going to be the first to stuff a 35R in there?!?!
Where ever it is I want a ride damn it! LOL
Congrats on the numbers,
Josh
Josh
#149
This friday I'm selling a Subary Legacy GT 2005 (sniff!), and going to replace it with the SS (love the Legacy, but I needed to create some liquidity). They state 5.7 or so for the 0-60 in that car, but frankly, that's BS. If I want to abuse the living crap out of my clutch I can do that, but one little mistake and all that traction I have is absorbed by the clutch, and there you go - clutch stink and wear.
What I'm saying is I don't put any faith in the 0-60 times of an AWD car to represent it's real-world performance. It's great for 1/4 mile numbers, and 0-60 numbers, if you have deep pockets for clutches, but in the realm of normal people, I put faith in 5-60, and trap times, which better remove the "crazy launch" from the equation.
The legacy is a quick and nice car, but in the real world the SS is a lot faster (5-60).
Mal.
EDIT: adding numbers. I had a hard time digging up these numbers and I'm sure there are better ones out there, but the following reviews show the 5-60 time for the EvoX at 6.1, and the SS at 6.2, so it would be a driver's race from a roll.
http://www.caranddriver.com/reviews/...omparison_test
http://autos.msn.com/research/vip/re...alt&icid=RSS_1
