Treadstone Intercooler Kit
Old Jan 26, 2011 | 02:14 PM
Treadstone's Avatar
Due to popular demand, we want to be able to adapter one of our TR8, or TR12 universal intercoolers that we give in our kit for the LNF to work with stock piping. Unfortunately when we first made the kit, we did a away with this option, but no all people want or need to replace the piping.
Brackets for the intercooler are done.
Driver side pipe: The one we have made will bolt to stock piping with just a coupler, so that is done.
Driver Side: We made a whole new up pipe. So what we need to do is just cut a 2.5" 90 degree pipe down to the right length to bolt on to sock piping with a coupler.
If someone whats to take on this task, all they have to do is measure the pipe on the passenger side, cut it to length take some pics, and report back.
Who ever is up for the task can get an intercooler kit at 50% off retail price.
When all is done, we will be able to offer the TR8 intercooler as a direct bolt on for under $300
Old Jan 26, 2011 | 02:47 PM
Dart_SI's Avatar
bump for good product
Old Jan 26, 2011 | 04:18 PM
RyRidesMotox's Avatar
Maybe I just got a prettier one but mine is all nice and shiny chrome on the endcaps. Bump... sic ass intercooler you won't be dissapointed.
Old Jan 26, 2011 | 05:39 PM
silverbullet08's Avatar
I will be a owner of one of these by the end of the week Il report back on anything i find.
Old Jan 26, 2011 | 06:58 PM
tom.g's Avatar
Under $300 for a full IC kit (without piping ofcourse) would be a pretty good deal
Old Jan 26, 2011 | 07:25 PM
First dibs on the 50% off!! Pm sent!!!
Old Jan 27, 2011 | 09:18 AM
pbass's Avatar
I'm up for this. But I'd mount the bottom of the IC 1/2" higher than the bottom of the condensation tank on the stocker.
This is because it's very easy to scrape the plastic condensation tank mount on the pavement, but with a stocker the tank is pretty much structurally independent of the IC, so we can throw the tank in the trash, epoxy up the holes and drive on.
If we smash any part of the solidly-assembled IC core, that's much worse. So a full half inch added to the clearance of the bottom of a tankless IC would be a good precaution.
Also it would be an important selling feature for folks like me who are replacing a scraped IC and want to make sure they'll never have to replace it again.
This high mounting can lift the top of the IC out of the best of the airstream. If an IC were a type of radiator, shedding heat as it was generated, this would be less than optimal. However, I subscribe to Julian Edgar's proposition that, far from being any kind of radiator--which is how most folks perceive the IC--it is rather a heat sink, or a heat storage device that need not get rid of heat at the same rate it gains it.
In other words, when we're on the boost, compression heat is stored in the aluminum of the IC for later disposal. Yes, air passing through the fins removes heat from the aluminum, but even more, it is the air moving through the inside of the intercooler which does this (Julian has observed this phenomenon for a long time--he goes even further with his state-change IC idea, but it's so different you'd spend a fortune trying to convince folks it works).
Another thing worth nailing down is a good flexible mounting system. Rubber isolators would be not so much to provide flex in case of impact, but mainly to provide isolation from vibration to protect against mechanical failure for the life of the car.
Old Jan 27, 2011 | 09:43 AM
G Speed's Avatar
I like him ^
Old Jan 27, 2011 | 10:07 AM
@ PBASS:
Having mounted the TR8 on my car I can assure you that it mounts higher than the stock one by quite a bit. I didn't get measurements but it is more than 1/2 and inch. It's a really quality piece and I didn't use any rubber isolation mounting anything. Many people on here just solid mount intercoolers like this. Since you don't have to worry about damn plastic endcaps there isn't much of a reason to rubber mount it. If you get it, enjoy! It helps me sustain very close to ambient air temps on multiple pulls when the stocker would begin to warm up. I run about 2 - 4 degrees above ambient air temps usually.
Old Jan 27, 2011 | 10:29 AM
northvibe's Avatar
Originally Posted by RyRidesMotox
@ PBASS:
how low does it hang though? The TR8 is 7.8" tall. The mpx so far is the only one that doesnt hang below stock and that is 6.25" tall. The zzp one is 8" tall. so Ya if its mounted higher it may not hang below, but I want to see pics...
Old Jan 27, 2011 | 10:33 AM
I had a build thread on here...
linky
Its the last picture at the bottom of the first post.
Old Jan 27, 2011 | 10:35 AM
pbass's Avatar
That rawks. Most of the ICs out there hang low.
In my limited experience, welds and vibration are a chancy mix. Many performance mods increase vibration and shock in the car. Seems like relatively cheap insurance. No one knows 'til after a manufacturer has a number of units out on the street for a while. But in the case of having to exchange units by mail for repair, you already have less than 100% customer satisfaction--that is, if you can afford the recall program.
Sweet!
Old Jan 27, 2011 | 10:40 AM
Welds are phenomenal on mine. all the vibration of the motor and such is isolated cuz of motor mounts anyways. And rubber mounts aren't gonna do a whole lot on big road bumps or something like that. I can see what you are saying for piece of mind and such but I don't have a problem with it myself. Having done plenty of welding myself in the past, I am not worried unless I hit something... Which almost happened yesterday actually, damn coyote ran out of the bushes at my car I was doing like 60 down a 2 lane road, almost pissed myself.
Old Jan 27, 2011 | 10:42 AM
northvibe's Avatar
linky
ah nice. Can you snap a pic from the bottom?
Here is the pic he has:
This is kind the pic I want:
From mpx of stock ic:
mpx ic:
I am fine with it at stock hanging height, but lower than that and I'll be breaking it.
Old Jan 27, 2011 | 10:44 AM
Yea I'll do that in a bit, I'm hung over right now and don't want to move out of bed.
Old Jan 27, 2011 | 10:48 AM
pbass's Avatar
Welp, your confidence may well be borne out as the miles pass. Watch out for those critters!
Old Jan 27, 2011 | 10:51 AM
northvibe's Avatar
hahha cool man
Old Jan 27, 2011 | 11:36 AM
northvibe's Avatar
oh we have critters in MN, but so far during 2 summers Ive only scraped the bottom of the lip not hit anything. so if it hangs lower its going to damage the crap out of an ic. So the ic NEEDS to not hang lower than the stock one.
Old Jan 27, 2011 | 11:58 AM
pbass's Avatar
@Treadstone: Looking forward to a direct bolt-on, hi-mount, sub-$300 TR8, the sooner the better!
Old Jan 27, 2011 | 02:17 PM
Dibs are back up for grabs on the intercooler i had to order one due to my factory one being so bad and in need of the car. I ordered a different one and had it overnighted. Is a little cheaper than treadstones but im not sure about quality till i see it in person. Wish i could have gone with treadstones but I was in a desperate situation and couldnt wait another day.
Old Jan 27, 2011 | 02:57 PM
Treadstone's Avatar
first one to call us up get the discount!
Old Jan 27, 2011 | 05:34 PM
pbass's Avatar
Thanks Treadstone, now I have a new project!
OK, he's sending me the GT8 IC with brackets plus two 90° aluminum elbows, and (I guess) two 90° silicone elbows and two straight connectors, $175.
He wants me to cut the aluminum elbows so the IC rides at stock height and send him the measurements.
But he says the bracket allows for vertical adjustment.
Since I want the measurements for the IC higher than stock height, I'll cut the longer length first and measure, then cut and measure the shorter length.
He said once finalized, he can send me the powder coated and bead rolled finished pieces. I'm hoping he can do that for my higher mount (longer elbows, I'd guess).
He's shipping tomorrow, so it'll probably be done early next week.
Old Jan 27, 2011 | 06:58 PM
tom.g's Avatar
Awsome thanks for doing this.
Old Jan 27, 2011 | 11:27 PM
northvibe's Avatar
sweetness let us know
Old Jan 27, 2011 | 11:55 PM
Here is a picture... Hope this is kinda what you are looking for as far as an example of how the intercooler hangs. It is from my phone... Basically I put the top of the phone against the bottom of the intercooler and took the picture.
