Treadstone Lower charge pipe
I really wish I would of bought ZZPs. First off, it came with no bolts for the MAP sensor so I had to go find some new ones. Then the hole for the MAP sensor was not drilled correctly so there was a lip, so I had to grind down the lip to get the sensor to fit. I have a massive leak coming from there so my car has been running like ****.
I'm just frustrated that I've taken the lower charge pipe off 4x to fit the MAP sensor cause it wont stop leaking.
omg thank you. I thought I had to buy a whole new sensor. I will look it up
