Trifecta tune with K&N SRI
If I get the Trifecta tune with K&N SRI do I have to always have the tune on? The reason I am asking is because with stock tune with intake skews the fuel trims right? I would like to have it off if Im not racing someone or going down the track.
I have the KN short ram with trifecta switchable tune with the cruise control. It works fine, you wont need to put it into stock once you see how it feels with the tune.
corn gas ftw....
Trifecta isues two seperate tunes in one. a high boost and a low boost application, the high boost setting will be your performance tune. and the low boost will be for daily use or whathaveyou. both the tunes will be optimized for any mods the car has
corn gas ftw....
yes you can now select the custom tune or stock tune on the same file, this is BEFORE loading the tune to the car though....while the tune is on the car you will only be able to select from low/high boost settings
