Turbo Flutter
A few weeks ago I had a local member tune my car. I was GMS1 before. I got him to give me a very mild tune over gms1. I am only running 21 psi and only about 12 degrees of timing. The car works great and has a lot more power then before. At wot I am NOT getting or hearing any turbo flutter. But , if i am in a parking lot just slowly trolling along in 1st gear and at about 10 or 15mph and let off the gas. I hear a very faint turbo flutter. That is the only time I hear it si far. It doesnt do it in any other gear at all. I am wondering if this is at all normal and if it will cause my turbo to blow sooner then later ? Or is it fairly common and harmless in small amounts ?
I should note. That I am running the know. So i never heard the turbo or noise before maybe ? Maybe it was always there before. The day he tuned my car I installed the intake so he could tune for my kn. I am also NOT running the vac tank anymore if that AT ALL causes any of it, I broke it years ago by mistake ..
Under all other conditins and times my car works great and perfect. It now shreds my poor tires in 2nd gear. And even after a wot pull. I get and hear no flutter at all. Any thoughts ? Thanks
It's cause of the vac tank delete. The vac tank stores vacuum to open bp valve quicker, without it it's slightly slower and at low load it ur car won't pull vacuum fast enough to open it on time. If u have a forge bpv make sure u have lighter spring in, it helps a lot. Otherwise u have to live with it
So the small amount of turbo flutter i have now is no worry at all ? Like i say. It only happens in 1st while im coasting a few seconds later for a split second.
Honestly.. I dont know the difference between the two ?? All i know is what i have is veey faint and doesnt happen all the time. Lol. I just dont want to hurt anything. I imagine it is a faint amount of flutter. But what is the difference between them ?
If it's only happening in first it's just a symptom of a low boost. The k&n just amplifies the sound that was always there and you just couldn't hear it. As long as it isn't doing it in other gears I wouldn't worry about it. If it does and you feel power loss it's probably going into limp mode and there may be a code logged that isn't a cel. Usually a symptom of gms1ower tmap sensor wiring.
Surge is when ur at wot and ur turbo is trying to hit full boost and starts to flutter when gas is on the floor. Zfr do that a little at around 4-4500k rpm it's a pain to tune out. I got mine pretty well gone but still does it a little one in a while. Not enough to do damage
Turbo Flutter
You'll know when it's surge, nothing like the flutter. With surge the car feels like it's misfiring and bucking and it's louder than flutter significantly.
Yikes, I might be getting surge!
So, is it the spring on the BPV that I need to check?
The car cuts out sometimes between 5-6k, I thought it was possibly dirty intake valves. Got some seafoam to run through it, but haven't done it yet.
So I get flutter dump a bit with my Forge BOV, also I find the let off totally annoying like its too easy in everyday traffic (I commute) So I thought about using a yellow spring. Now watching that video I definitely have that "issue" I quick flutter before full dump,
