turbo flutter and higher boost spikes
Old 06-02-2012, 12:04 PM
bucks121's Avatar
i recently got tuned with trifecta not realizing i said i had gms1 sensors which i dont and i think it caused me some problems. for the past day ive been trying to flash to stock and it seemed like it wasnt flashing i had a few codes P0036 and P2227 today i managed to get it to do a force full flash it made the car drive a bit normal.
at this moment i didnt drive much so there is no cels but i currently have loud turbo flutter and my car is boost spiking around 120-125kpa i think 100kpa is stock?
if anyone has any suggestions on what i could try and do it would be great
wot support says vince is going to write me a tune without gms1 sensors i hope its today and i hope it fixes everything
Old 06-02-2012, 01:20 PM
bucks121's Avatar
so i just went for another drive i now have the cel P2227 again
also the flutter only happens when i let the gas off, shifting etc at lower boost its more quiet and higher boost its alot louder my car isnt in limp mode it still boosts over 5psi but it will boost more then it should around 120 kpa
Old 06-02-2012, 04:30 PM
bucks121's Avatar
Does anyone know what the barametric pressure sensor does ?
Old 06-02-2012, 07:13 PM
peachpuff's Avatar
Tell vince you have the gms1 sensors otherwise that p2227 code will pop up.
Old 06-02-2012, 07:22 PM
Sunburst_SS's Avatar
Measures barometric (atmospheric) pressure......it's intergrated to the ecm. It measures open atmosphere.....not manifold/boost pressure.
Old 06-02-2012, 07:29 PM
bucks121's Avatar
i dont have gms1 sensors and i apparently flashed back to stock and now i have that code P2227 and my car is boosting past the normal kpa for stock and i have turbo flutter could a bad tune/flash cause all of this?
Old 06-02-2012, 07:56 PM
Frogstofall's Avatar
Ths is correct. I read his question wrong.
Old 06-02-2012, 11:04 PM
peachpuff's Avatar
Derp read that wrong, yes that's going to screw up baro readings.
Old 06-28-2012, 12:08 PM
lebulbe's Avatar
I have the exact same problem.
I had trifecta dual tune 24 psi put on 2 years ago and was working fine.
then i had stock tune put back on last autumn and the p2227 + flutter started the next day.
i lived with that for the winter and last week I put my trifecta tune back on the car. the flutter and p2227 went away the first time I took the car after the tune but came back right the second time i started the car.
i bought the car used so i'm not sure if i have the gms1 but the guy told me he had put a tune not sure if it was GMS1.
anyone have a clue of what could be the problem ? i'm almost sure it's related to a tune or a setting because it went away just after i put my trifecta back last week but came back right after.
thank you !
Old 06-29-2012, 10:39 PM
gone_in_10_sec's Avatar
thank you !
did you get the car from GM dealership? if so - the tech who serviced the car before the car went on the used car lot, it's possible he reflashed with the GMS1 tune.. with the tech thinking there was a GMS1 flash that came originally with the car..
also I would send Vince@trifecta an email of a copy of your log file with a description of the problems your having that you've encountered up to now..
Old 07-05-2012, 09:32 AM
lebulbe's Avatar
i got the car reflashed with the trifecta for GMS1 and same thing happened. Everything was working great the first run then when I got back from work like 4 hours after the flutter sound was back and soon after the check engine P2227 also.
Here's a video of the sound the car make :
cobalt ss 2008 Turbo flutter problem - YouTube
Old 07-07-2012, 06:57 PM
jran's Avatar
I just tuned my car yesterday with trifecta and I am having the same exact issue right now.
Old 07-07-2012, 07:33 PM
SSlobalt's Avatar
In cases where you weren't having an issue, then started having one after a tune, I'd say to disconnect the battery for 10 minutes and try again or reload the tune.
Old 07-09-2012, 04:49 PM
jran's Avatar
Yes I had no problems before the tune and I have reloaded it and I am still experiencing the same issues.
Old 07-09-2012, 04:53 PM
Dart_SI's Avatar
Are u guys letting your car idle and sit for a minute after loading the tunes or just loading the tune and driving away?
Old 07-09-2012, 04:57 PM
jran's Avatar
I always let my car idle for a bit before I go and drive.
Old 07-16-2012, 05:50 PM
lebulbe's Avatar
i will try to unplug my battery for 10 minutes and give you a feedback
Old 07-19-2012, 11:33 AM
lebulbe's Avatar
i didn't had the chance to unplug my battery yet....
anyone else found the cause of the problems ???
this is very anoying and sound very loud with my K&N CAI
Old 07-23-2012, 05:54 PM
jran's Avatar
I found that my tune was setup for gms1 when I dont' have gms1. After I got the file without gms1 I've had no problems.
Old 08-03-2012, 09:11 AM
lebulbe's Avatar
well i was unsure whether i had GMS1 or not so i asked my tuner to put the tune with GMS1 now the car run like crap and I still have the turbo flutter FML.
Old 08-03-2012, 01:38 PM
SSlobalt's Avatar
Do you register boost when you rev it up in neutral?
Old 08-10-2012, 04:48 PM
lebulbe's Avatar
i will check that as soon as i get into my car !
Old 08-10-2012, 08:57 PM
lebulbe's Avatar
Yes i get 20-30 kpa of boost when i'm in neutral
What does this mean ?
Old 08-10-2012, 10:13 PM
SSlobalt's Avatar
Your TMAP sensor is bad, or the wiring for it is shorting.
Old 08-22-2012, 10:06 AM
lebulbe's Avatar
ok so would this be the good part ?
SOLSTICE SKY HHR COBALT 2.0L LNF MAP SENSOR 15292016 213-3843
also where is it located ?
thank you !
Quick Reply: turbo flutter and higher boost spikes
