turbocharger not making boost
Old May 28, 2013 | 05:19 PM
09BlkCrusader's Avatar
Exclamation turbocharger not making boost
while driving, the boost gauge will not go higher than 0. I'm not very sure what's going on so I'm asking on here for some help and a list of things to check. I DO hear the bpv when I try to make boost but it still won't actually produce said boost. any help would be appreciated :-\
edit: I will try to produce as much info as needed. please ask and I will try my best to give you answers.
Edit: It isn't a consistent issue, it will drive fine for random miles then suddenly not go above 0, sometimes it will throw a P0101 sometimes it won't. If i turn the car off then back on, it will "fix" the problem but will activate again after a mile or so.
I also have not had any issues until I tuned the car.
Old May 28, 2013 | 05:21 PM
Sox-Fan's Avatar
Got Brakes?
boost leak check. What code are you getting?
Old May 28, 2013 | 05:28 PM
oddly enough no code yet. I drove to work and I'm at work right now. is there anything I can do while I'm at work? Boost leak test may have to wait but I can try to inspect all the ic pipes and intake. is there anything else I can check visually without tools?
Old May 28, 2013 | 05:29 PM
Sox-Fan's Avatar
Got Brakes?
Check that the end tanks are not cracked, that the drip tray at the bottom hasn't been ripped off. Those are always the first places to look.
Old May 28, 2013 | 05:30 PM
I feel stupid asking this but.. the drip tray?
Old May 28, 2013 | 05:36 PM
Sox-Fan's Avatar
Got Brakes?
Because it's at the very bottom of the intercooler and as it is the first thing that meets the ground or parking lot curbings, it is frequently ripped off, leaving a small hole at the bottom of the intercooler.
Old May 28, 2013 | 06:07 PM
okay well I did a visual inspection, everything was fine.. got in the car, started it up, went down the road, turbo didn't create boost. turned around and tried again, car made boost. tried 3 more times, each time made boost..
any idea? Lol
Old May 28, 2013 | 06:15 PM
Sox-Fan's Avatar
Got Brakes?
gremlins
Old May 28, 2013 | 06:18 PM
Haha could it be some sort of spring in the bpv or wastegate?
Old May 28, 2013 | 06:52 PM
SSSnoop's Avatar
Not to jack the thread, but I'm suspecting my stock bpv may be bleeding off some boost - it sounds almost similar to this "not making boost" situation, but I can still kick up decent pressure, and no codes. I have CAI, so I normally can hear when the bpv operates - wondering if its a common thing to have these things part-way fail like that, especially stock.
Old May 29, 2013 | 08:32 AM
Okay so driving to work today, car did it again lol do I turned the car off then back on and it worked briefly then the car did it again and threw a cel. Will let you guys know what the code is.. maybe then I can get it figured out.
could it possibly be a bad maf sensor?
Old May 29, 2013 | 08:38 AM
Whitty's Avatar
I had this exact issue the other night as well I stopped freaked out turned the car off and on and haven't had an issue since. I'm going with gremlins until it happens again. in for the results of what you find out.
Old May 29, 2013 | 08:48 AM
Terminator2's Avatar
Sticking or leaking BPV or bad check valve in the vac tank (causes BPV not to work properly) or a bad boost leak. Need to know what codes are pending or thrown to know for sure.
Old May 29, 2013 | 09:12 AM
Whitty's Avatar
in my case im certain it isn't boost leak but i dont want to thread jack once i know more term I'll likely be in touch.
Old May 29, 2013 | 11:12 AM
Okay well I reuploaded the tune and now I'm not having any issues. Logged the car, so far so good.. Will keep this thread updated.
I threw a P0101 MAF Performance
Also a Camshaft positioner error which was after the P0101
Cleared both codes, retuned car, so far no issues.
Old May 29, 2013 | 11:41 AM
P0101 is a MAF performance code which almost always indicates a boost leak. If it comes back or is still pending you likely have a leak
Old May 29, 2013 | 12:21 PM
Well in parenthesis it said (bad). Been running the car up and down and so far no issues. Still trying to figure it out though.
Old May 29, 2013 | 12:24 PM
Whitty's Avatar
build yourself a boost leak tester from home depot parts (super easy and google-able, yes i used google as a verb) it only takes ya an hour tops to test it and youll know for sure. there is a how to on it as well in the how to section
Old May 29, 2013 | 12:28 PM
cobaltss#01's Avatar
I was having the same problems 2 weeks ago. It was the end tank cracked on intercooler.
Old May 29, 2013 | 12:38 PM
I checked the entire intercooler and piping and found nothing, and I've been driving it all day since i re-flashed the tune everything is fine, but I'm still checking everything from time to time.
Old May 29, 2013 | 02:27 PM
I unplug for one second lol and the code strikes again!
[] P0101 - Mass Air Flow (MAF) Sensor Performance (SES) (Old) (History) (Current) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Incomplete
Heated Catalyst: n/a
Evaporative System: Incomplete
Secondary Air System: n/a
A/C System Refrigerant: n/a
Oxygen Sensor: Complete
Oxygen Sensor Heater: Complete
EGR System: n/a
Old May 29, 2013 | 02:33 PM
Sox-Fan's Avatar
Got Brakes?
smells like boost leak.
edit - oh, try bypassing the vacuum tank and see what that does.
Old May 29, 2013 | 03:13 PM
If it's a boost leak, how come it would come and go? Wouldn't it be a permanent issue not temporary?
Old May 29, 2013 | 03:20 PM
Whitty's Avatar
I had a boost leak on GMS1 that term helped with diagnose. in the end my entire hot side pipe was blown off the IC but the symptoms were still intermittent at the time I had the following code.
[ECM] P0101 - Mass Air Flow (MAF) Sensor Performance (Old) (Immature)
Build a tester and get it over with
Old May 29, 2013 | 03:38 PM
It is not a massive leak it is just barely big enough to trigger the MIL which is why it comes and goes also it takes 3 consecutive fault cycles (key cycles in which the fault is sensed) to trigger the MIL. There is a remote possibility it is a MAF turbulance issue (seen this mostly with MAF relocate cars) or vac leak right at the MAF (seal could be leaking).
