twincharge ss/tc?
the computer in the LNF likes to fight everything you throw into it. I do believe its ZZP that's posted a thread about this and says that everything they throw into it, it fights back agianst it because the HPT isn't advanced enough for the LNF computer yet. Something about the fuel tables I think.
I still wont put it out of the question for an LSJ. Just don't do it the way ZZP did...
Lets just start thinking of crazy things to do.
How about twin turbo an LNF. Use a turbo at the manifold and one that is rear mounted. One for quick spool and one for big power.
That sounds fun.
That sounds fun.
I wouldn't bother. Having said that I think it's a cool idea. Not something to do seriously though.
Someone does that from the factory. I think it might be BMW. It's a two stage design. Small turbo for quick spool and then a big turbo for high rpm big power.
just do a turbo upgrade. its easier and if you buy the kit from synapse and install it yourself, your only looking at 4grand plus tuning. but the kit comes with the HPT tunning software. just a thought. thats the way i am going to do it.
yep and i see it being very expensive for you guys to swap injectors. usually since they are such a high pressure system, injector swaps usually involve swapping out the fuel pump as well
Modifying the flowdisc inside the stockers will work but we have no tuning for higher flow injectors, and at $450 a piece the injectors are expensive to replace if you mess one up.
tiwncharging works like this:
supercharger feed the turbo. Turbo boosts and makes 95% of the power.
Ur stock turbo is ITTY BITTY, and it would be COMPLETELY USELESS to twincharge it... Dont be stupid, its going to FAIL miserably if u try and pull this off WITHOUT a turbo upgrade.
the Epic FAIL Threads Compilation Thread...
