Ummm... Problem
Old Jul 28, 2009 | 02:06 PM
Shibito's Avatar
Ummm... Problem
Alright, so yesterday my friend noticed black smoke coming out my exhaust when I would leave traffic lights. Well, I checked it out this morning and she puts out a little when I start her and she'll put out a little when revving up to like 5k or higher. Does any one have any clue what this could be? All I have done is a tune.
Old Jul 28, 2009 | 02:07 PM
09turbo's Avatar
running rich maybe? my car puffs smoke bad when i shift WOT
and im stock
Old Jul 28, 2009 | 02:09 PM
Shibito's Avatar
and im stock
Alright, my main concern was it was an isolated problem with just mine. This is the first time it's ever been brought to my attention.
Old Jul 28, 2009 | 02:17 PM
383_Stroker's Avatar
Black Smoke is Rich Smoke..
Old Jul 28, 2009 | 02:20 PM
BumbleBee's Avatar
my friend said the same thing when i left a parking lot, I just figured it was because of my stage 2 tune.
Old Jul 28, 2009 | 02:21 PM
Shibito's Avatar
If it helps, when I floored it in 2nd the A/F ratio held around 12
Old Jul 28, 2009 | 02:37 PM
wantedSS/TC's Avatar
even stock it runs a little rich. The beauty of DI cars. When I first turn mine over in the morning I have soot coming out for 30 seconds or so. I'm stock btw.
WOT I only hit 13 at my lowest.
Old Jul 28, 2009 | 02:51 PM
20redline's Avatar
car blows black smoke from the factory. i use to have to wash my bumper everyday from the black smoke. now im tuned so no more black smoke only when i nls.
Old Jul 28, 2009 | 02:58 PM
20redline's Avatar
Old Jul 28, 2009 | 08:25 PM
Turbo'dSS's Avatar
sry but i have no clue what WOT is... i see it all the time and never knew what it meant. help?
Old Jul 28, 2009 | 08:28 PM
ssturbo305's Avatar
wot = wide open throttle aka gunning it lol
Old Jul 28, 2009 | 08:30 PM
Mazdaboi318's Avatar
Wide Open Throttle
SP ^^
Old Jul 28, 2009 | 08:35 PM
alex_mcg's Avatar
Yea, I can't wait to start my car next to some prius or other hybrid lover. Their jaw will hit the floor when they see all of my heartless pollution of the earth.
Old Jul 28, 2009 | 08:54 PM
Married w/children's Avatar
Look at the inside of your exhaust tip...that's one hundred percent ozone depleting love. Or soot as some call it.
Old Jul 28, 2009 | 09:01 PM
Shibito's Avatar
Turns out I was running quite a bit rich. Did some tuning and I'm back where I should be with AF ratios. Thanks guys!
Old Jul 29, 2009 | 06:32 AM
IsItFast?'s Avatar
Originally Posted by wantedSS/TC
even stock it runs a little rich. The beauty of DI cars. When I first turn mine over in the morning I have soot coming out for 30 seconds or so. I'm stock btw. WOT I only hit 13 at my lowest.
Actually the cars run very lean for a turbo car, if you compare it to a non-direct injection turbo car. The dyno guys (who had never dyno'd a DI car) were concerned when they saw it! The black smoke coming out the back is pure SOOT. Soot is a byproduct of the DI process, the same process that produces soot from a diesel. Under transient conditions GDi engines produce about as much soot as a modern diesel engine. Even properly tuned, the car will cause the tailpipe to get black fairly quickly. It wont be long before particulate filters are required for GDi cars as they are now for diesel.
Old Jul 29, 2009 | 10:00 AM
Terminator2's Avatar
What did he have your commanded lambda at ?
Old Jul 29, 2009 | 10:30 AM
Shibito's Avatar
Not sure, all we had to do to fix the problem was mess with the long term fuel ratios.
Old Jul 29, 2009 | 10:35 AM
Your car is stock other than a tune correct? If so, your MAF tables should not have needed to be touched. Your fuel trims should have been off by less than 1%.
Old Jul 29, 2009 | 10:39 AM
Shibito's Avatar
Yea, I believe the long term was off by 6%
Old Jul 29, 2009 | 01:23 PM
Turbo'dSS's Avatar
Originally Posted by Mazdaboi318
Wide Open Throttle
SP ^^
Thanks!! lol!
Old Jul 29, 2009 | 01:43 PM
Donny Brasco's Avatar
What tune are you using?
Old Jul 29, 2009 | 01:53 PM
He has a custom tune by someone in his area.
Old Jul 29, 2009 | 03:03 PM
Shibito's Avatar
Yep.
Old Jul 29, 2009 | 03:08 PM
KillerBee's Avatar
Who tuned you?
