Upgraded HPFP? Hello ZZP? Anyone?
Greetings and hallucinations!
I know I for one would be interested in the possibility of obtaining a higher volume High Pressure Fuel Pump. With the recent turbo upgrade developments and some of us switching to E85 I believe the market will be growing for this as more and more people up the power via Trifecta or the new tables HP Tuners has opened up for us recently with larger turbos and fueling changes.
There are already options for the LPFP if needed (Walbro iirc) from what BYT has posted in the past.
If enough interest is shown perhaps one of our platform supporters will see if they can help us out with an offer.
Let your interest be known!
I'm looking to increase flow volume, not pressure. I've run up to 2800 psi on the injectors & fuel rail without any issues although I know of one rail failure at 2800 psi at a braised joint. Stock HPFP does best around 2200 psi on mine from the logs Vince read last week. Pumps have a flow/pressure curve and there is a sweet spot where it is the best.
So far the HPFP is the weak link for most. LPFP might be next. IDK if ZZP had to upgrade the LPFP or not on their builds, hopefully they will chime in.
I'll see if I can find the BMW forum post that outlined how they were incresing the fuel volume on the hpfp again. (96sunfire from the hpt boards Tom)
ETA; Might of been a VW forum? Want to say it was APR maybe.?.?.
Yes the mechanical pump under the hood is the hpfp while the intank pump is a lpfp.
As stated before the mazdaspeed guys have a upgrade for theirs but that stims from the problem they run into that their pumps actually start to die in efficiency and deteriorate over time, which brought about the development of stronger hpfp internals for theirs.
Did not read the whole thread, but based off the first post and the thread title this is not what he is talking about. This would be considered a lpfp which drives gas from the tank to the hpfp which then pressurizes it for the high flow rate that the direct injection system requires.
im still running the stock fuel system without raised rail pressure and ive made quite a bit power. zzp still runs their stock in-tank pump and im pretty sure they run the stock cam pump too.....
not to mention not all of the kappas are direct injected.
e85 is like race gas level. you cant compare 93 octane to e85. you compare with 100 octane that is around $8 gallon to e85 in the east with is prob like 2.50-3.20 max! with race gas you will make more power than e85 cause you can flow more as you guys are saying with about the same level octanes
if you look into HPFP's and upgrade...you'll realize the 2.3L MZR ones are actually based off the VW crowds upgraded pumps. And if anyone listened to me over a year ago the VW people have upgraded injectors as well for DI. So if someone had a spare pump I'm sure you could send it off to one of a few companies and see what could be upgraded. I have a spare MZR 2.3L HPFP...but of course that does us no good.
But werent their pumps complete garbage to begin with?
